20 Most Recent
Powmax ATX Power Supply Tester Power Supply Questions & Answers
I have a Power Judge
Try to measure voltage on power supply with a more acurate tester and you will see if your power tester is good or not. This is the easy way to control acuracy of your tester.
Reconnecting 2 cables to the
I'm not sure what exactly your referring to. The Powmax UPS system doesn't have any cables to connect. At least not on the outside. If your referring to the inside of the UPS system, what are you trying to hook up? Perhaps you can repost what it is your referring to so I can help.
Thanks
Mark
Hi!! Thank you for your time! We're doing our
A few questions. Is it an stand alone one? seems to me a 500VA rated UPS, for light loads only.
Some stand alone common problem.
1. Battery for replacement
2. Fuse busted
3. Faulty relay
If repair and battery replacement outweighs the new one or got a small difference. Its better to have a new UPS unit.
Hope this helps
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
