20 Most Recent Rowenta DE851 Iron Questions & Answers
Hey, You have a "Mildew" issue. Just like leaving clothes in the washer too long before putting them into the dryer. If you read your iron's manual, it is recommended to use "Distilled" water...not tap water. Tap water has impurities...Distilled water does not. Here's the fix...MAKE SURE YOU ARE HOME WHEN YOU DO THIS! Get distilled water (From Grocery Store) Mix 1/2 cup distilled water with 1/2 cup vinegar. Put this into your iron and leave it on. To help it along, push the "Steam" button frequently. You can do this several times...the acid in the vinegar will clean out the residue. Once this is done, fill the iron with water, add a couple of drops of lemon juice and you'll be good to go. I know this to be fact...just did it myself : )
Rowenta DE851... | Answered on Apr 12, 2014
Only if you check up with Rowenta this part will be available but if you can search around in service shops you may be able to salvage one from a coil damaged iron that was discarded.
If not fabricate the top with a fibreglass or plastic repair shop and it can be doe to suit the top after a paint job.(If broken use good glue and then paint on top)
Rowenta DE851... | Answered on Aug 31, 2010
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Rowenta DE851... | Answered on Aug 24, 2009
They are built to shut off after about 30 sec or so if the iron is not moving and the iron is in pressing position (sole plate down). They shut off if they are not moving and standing with the sole plate vertical, in about 5 minutes. If you move the iron (like ironing) they reheat. If it doing something else the electronic control is defective. It is cheaper to replace than repair.
Rowenta Irons | Answered on Nov 03, 2019
Rowenta DE851 Iron Logo
12 questions posted
Top Rowenta Irons Experts
Paul Bade
Fahr Quad
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
View Most Popular
Rowenta Irons
  • Rowenta Irons
Most Popular Question
iron smells bad transfers smell
  • Irons
