20 Most Recent
Panasonic PT-AE1000E Projector Lamp Replacement Questions & Answers
How to replace the lamp for Panasonic projector
If you bought a lamp from eBay then its most likely not a real brand bulb. The PT-AE1000 uses an ET-LAE1000 lamp that should have an Osram, Philips or Matsushita brand bulb. If you do not see PVIP, M or UHP on the bulb then its most likely your problem. Cheap lamps are not worth the money. They fail early and end up costing you more money in the long run.
Panasonic Projector Lamp
These folks sell lamps that always work. I would return the eBay lamp and buy one that will work. Their support and customer service are one of the best in the industry.
9/15/2015 12:55:43 PM •
Panasonic...
Answered
on Sep 15, 2015
Why does the lamp shut off on the Panasonic PT-AE1000E Projector within 1 minute of starting?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
1/14/2015 11:50:40 AM •
Panasonic...
Answered
on Jan 14, 2015
Panasonic KX-MB2025 Toner Low Problem???
Does the machine say replace drum or toner. Two different units. If toner did refill or install a new toner. There is a chip on most drums and toner to tell the machine they are new. if you refill the toner the chip is still going to tell the machine it is used.
Panasonic DP-C266 does not print one color
If your Panasonic DP-C266 copier is not printing yellow and you have already attempted some troubleshooting steps, here are a few additional suggestions to consider:
- Verify Toner Cartridge: Confirm that the yellow toner cartridge is installed correctly. Ensure it is securely inserted into the copier and that any protective seals or tabs have been removed from the cartridge.
- Check Toner Levels: Check the toner levels of the yellow cartridge. If the toner is low or depleted, replace the cartridge with a new one. Even if the toner appears to be full, it's possible that the cartridge may be defective or experiencing a blockage.
- Clean Developer Unit: The developer unit may have accumulated debris or become contaminated, leading to poor toner transfer. Open the front cover and locate the developer unit. Carefully remove it and clean it according to the manufacturer's instructions. Use a soft, lint-free cloth to remove any toner or debris. Avoid touching the developer roller with bare hands.
- Check Drum Unit: The drum unit may be damaged or worn, resulting in the poor transfer of yellow toner. Inspect the drum unit for any signs of damage, scratches, or wear. If necessary, replace the drum unit with a new one.
- Perform Color Calibration: Use the copier's built-in color calibration feature to ensure accurate color reproduction. Refer to the user manual for instructions on how to access and perform color calibration. This process can help correct any color imbalances.
- Service or Professional Help: If the issue persists after trying the above steps, it may require professional assistance. Contact Panasonic customer support or schedule a service visit by a qualified technician. They have the specialized tools and knowledge to diagnose and address specific issues with your copier model.
When contacting customer support or a technician, provide them with detailed information about the problem, including the steps you have already taken for troubleshooting. This will help them in providing more accurate assistance and guidance tailored to your specific situation.
Panasonic DP-MB250. How to remove Call Service 5 on it please?
The "Call Service 5" error on a Panasonic DP-MB250 generally indicates a problem with the fuser unit. Here are some steps you can try to resolve the issue:
- Turn off the machine and unplug it from the power source.
- Wait a few minutes to let the machine cool down.
- Open the front cover and remove the toner cartridge and drum unit.
- Locate the green lever on the fuser unit and gently push it towards the back of the machine to release the fuser unit.
- Carefully remove the fuser unit from the machine.
- Check for any paper jams or debris inside the fuser unit or around the rollers. If there is any obstruction, remove it carefully.
- Reinstall the fuser unit, drum unit and toner cartridge.
- Close the front cover and plug the machine back in.
- Turn on the machine and check if the error message has cleared.
If the error message persists, you may need to replace the fuser unit. Contact a certified technician for assistance.
Panasonic KX - HCM10I need the driver for this camera model I need driver installation for this camera.Panasonic KX-HCM10
You can download the driver for the Panasonic KX-HCM10 network camera from the Panasonic website. Here's how to do it:
- Visit the Panasonic website: Go to the Panasonic website (panasonic.com) and click on "Support" in the top menu.
- Search for your camera model: In the search bar, type "KX-HCM10" and select the "Downloads" option.
- Download the driver: On the downloads page, look for the driver software for the KX-HCM10 and download it to your computer.
- Install the driver: Once the driver has been downloaded, follow the instructions for installation. You may need to restart your computer after the installation is complete.
After the driver has been installed, you should be able to use your Panasonic KX-HCM10 network camera. If you encounter any problems or need additional help, you can contact Panasonic customer support for further assistance.
Panasonic KX-FP215 "Fax in Memory"
A fax is retained in memory until printed (excluding memory limits). Given the failure to print and the continued "fax in memory" message, I suggest you try the photocopy feature of this device. If you try to copy something, it should force the printing of the fax.
The same thing can happen if you run out of paper. If the fax does not matter and you can't find instructions on how to clear fax memory, unplugging the device should clear the fax memory.
Panasonic KX-T7633 want to dial number before picking up receiver
Please first attempt a power cycle of the phone and then attempt your action again. If it fails, please attempt a factory reset before trying your calling process again. Otherwise, you can check the table to contents of the manual for dialing/calling techniques.
Thank you.
