20 Most Recent Russell Hobbs 3902US Work Top Blender Questions & Answers
There's a safety lock built into the handle of the jug. If the jug cover doesn't key into the lock properly, the motor base won't start.
Old blenders used to be able to start without putting the jug in place at all. I think this helps you know when the jug is in place properly.
It's indicated on the carton box; somehow I can't find my manual.
Cheers!
Russell Hobbs... | Answered on Oct 13, 2018
When you clean your blender there is a rubber washer in between the blades and where they sit and the glass. Try pushing the blade assembly through the bottom and locate the large washer. Peal it off carefully under warm water then either try to replace it or clean it carefully in soapy dish water. Let me know if this helps, OK?
Jud
Russell Hobbs... | Answered on Sep 20, 2010
Hi, i read your are having trouble with the tap on your blender. We pulled our blender out of the box and used it for the first time and it leaked through the base, through the motor all over the bench top.
At first i thought the tap was leaking too, then I investigated a little bit and found it was leaking through the white tension clips on the inside of the black base.
Then i discovered that there is a recess for an "O" ring, which seals the glass jug to the black base thus solving the leak.
However there was no "O" ring in the recess and now I am trying to find a replacement one.
Hope this helps.
Russell Hobbs... | Answered on Sep 04, 2010
  1. hold the base with ine handle and the jar with the other
  2. turn the jur to right hand side
good luck
Russell Hobbs... | Answered on Apr 13, 2010
check for the thermal fuse if it has blown inside. check if O -ring, has leakage and motor got wet some how or gummed up , clean you parts. try not to fill up the dump yards with more trash ... >^.^<
Russell Hobbs... | Answered on Mar 14, 2010
Look for a safety interlock switch that requires the bowl to be FULLY engaged before it will run.
These are OFTEN hidden a bit for aesthetics.
Russell Hobbs... | Answered on Dec 22, 2009
Dear
karan plz cheak motor unit swith anther
plz coll me
my ph no - 23051554 \ 23095757
mumbai
Russell Hobbs... | Answered on Aug 05, 2008
Hi there...
firstly is this blender a USA or UK model and do you have a Multimeter handy?
if you can remove the fuse from the plug (UK only) and test t through diode mode on a multimeter or Continuity test across the fuse terminals... if it beeps the fuse is good if nothing the fuse is blown
we can move on from there
Russell Hobbs... | Answered on Jul 22, 2020
Russell Hobbs 3902US Work Top Blender Logo
20 questions posted
Top Russell Hobbs Blenders Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Russell Hobbs Blender Expert? Answer questions, earn points and help others
View Most Popular
  • Russell Hobbs Blenders
Most Popular Question
leaking from around base jug
  • Blenders
