20 Most Recent
Kohler 1221-H-0 Seadream 6' Whirlpool Bath Tub with Heater Questions & Answers
I have a Kohler whirlpool. When I turn on the pump
Most likely the seal at the pump shaft is bad and the water leaks out as the motor is running...this can be fixed by an experienced plumber, but is rather difficult and parts are hard to find.
Replacing the whole pump and motor may be the best option...
heatman101
I have a 1980 kohler jacauzzi tub with 6 jets.
no not really the only way to fix it right is to open up the walls. this is a common problem with these units, the best thing you can do is contact the manufacture who made it and ask them what to do.
My bathtub drain leaks. Is there a product to
No, not without sealing, I mean clogging, the drain. Do you know exactly where the leak is coming from? I would suspect that the water is getting around the drain, instead of down the drain. The visible part of the drain should unscrew from the part that is underneath. That bottom part is likely permanently sealed to your drain plumbing.
You may be able to easily fix your leak by:
#1 Unscrewing the visible drain top.
#2 Replacing the washer under that top. This will seal your tub to your drain. All water will then be forced to flow down the drain properly.
#3 Screw the top of your drain back into place WITHOUT folding or wrinkling the new washer.
Good luck
II have a kohler jacauzzi
There may also be a breaker close to the tub and a reset button inside of the unit. I would begin by opening up the base and looking for a reset button. good luck
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
