20 Most Recent Kohler 1263-96 Folio 5.5' Drop In Whirlpool Bath Tub Finish: Biscuit Questions & Answers
Here is the manual for the tub. The switch is an air switch with tube. You have to make sure the tube has no holes in it or replace it if you can. look on the manual it will help you out.
http://www.us.kohler.com/onlinecatalog/pdf/1010564_5.pdf
Kohler 1263-96... | Answered on Dec 15, 2008
We had a problem with phantom flushing. Call Kholer. They will send redesigned battery holder and top of flush unit for free. Seems to have fixed the issue.
Kohler Home | Answered on Jan 09, 2020
The only batteries are in the docking station. If the remote is attached to the docking station, take that off and set it aside. Next, carefully lift the docking station up and out from the mounting bracket. Look at the back of the docking station, push the two tabs outwards (away from each other) simultaneously to open the battery compartment cover. Replace the batteries (4 AAs) in the correct orientation. Reinstall the cover. Then replace the docking station on the mounting bracket and put the remote back on the dock if desired.
These directions are shown in the Homeowner's Guide (without the service parts) available on the product page: https://www.us.kohler.com/us/veil-intelligent-comfort-height-skirted-one-piece-elongated-dual-flush-toilet/productDetail/toilets/1120267.htm . Scroll down to the Installation section to find the link to the document. The current link to this guide is https://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1226974_5.pdf .
I hope this helps.
Kohler Home | Answered on Jan 05, 2020
First, identify the style of your quick connect hose.
See the steps on this Kohler Fawcet Link for disconnecting your pull-out kitchen faucet quick connect hose. Follow this link: https://support.kohler.com/hc/en-us/articles/360001798834-Disconnect-Quick-Connect-Pull-Out-Kitchen-Faucet-Hoses
Make sure the water valves are closed and the water pressure is relieved before attempting to service your kitchen taps.
Kohler Home | Answered on Oct 12, 2019
The brand of toilet doesn't matter. You need a product that cuts calcium and lime. It may take some soaking and scrubbing. Once you get it clean, use the product regularly.
CLR makes a line of products:
https://clrbrands.com/en-US/Products/CLR-Household/CLR-Calcium-Lime-Rust-Remover
Kohler Home | Answered on May 10, 2019
I don't know this specific tub, but here's the pictoral. The button (90105) should come out of its base, held by friction of O ring. This should allow you to disconnect the pressure line. If you are looking to replace the complete assembly, likely you will need a basin wrench to reach nut (65157).
kohler1-ggmuzyqdnvlyrlfigj0gxfoh-4-0.png Here are links to Kohler, specific to this tub.
https://www.us.kohler.com/us/catalog/svg_viewer.jsp?productId=415928&diagram=3 https://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1010564_5.pdf
Kohler Home | Answered on Mar 18, 2019
Smart-a$$ answer is to find an old 3 gallon pot in a salvage place. Best answer is to fiddle with the chain that goes from the handle to the flush flapper and see if adjusting its length makes a difference. If it's too short it might result in letting the flapper closing too soon and allowing your deposit to remain.
Kohler Home | Answered on Mar 01, 2019
There's something blocking it sometimes if you turn the water off in your home and turn it back on sometimes calcium from the pipes break loose and cause blockage in new style washerless valve assemblies.
Kohler Home | Answered on Jan 11, 2019
Get a water hose,place in tub,connect to water outlet,turn on for a minute,then turn off.then disconnect hose,then water will come out.
Kohler Home | Answered on Dec 29, 2018
Kohler 1263-96 Folio 5.5' Drop In Whirlpool Bath Tub Finish: Biscuit Logo
2 questions posted
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
kohler whirpool tub will not turn
  • Home
