Hi!
If the "clean filter" light on your Brookstone Pure Ionizer continues to flash even after you've cleaned the filter, it's possible that the filter is worn out and needs to be replaced.
Since you're unable to find the model number of your air purifier, I suggest that you try the following steps:
- Look for the filter type: Check the user manual or the label on the filter to see if there is any information about the filter type or part number. If you're still unable to find this information, try removing the filter from the air purifier and looking for any identifying markings or labels on the filter itself.
- Contact Brookstone customer support: If you're still unable to find the filter type or part number, contact Brookstone customer support for assistance. They may be able to help you identify the filter you need based on the make and model of your air purifier.
- Consider a generic replacement: If you're unable to find the exact replacement filter for your air purifier, you may be able to use a generic filter that fits the same size and shape as your original filter. Be sure to check the specifications of the filter carefully to ensure that it will work with your air purifier.
In the meantime, you can try resetting the filter indicator by unplugging the air purifier for a few minutes, plugging it back in, and then pressing and holding the filter reset button (if available) for a few seconds until the indicator light turns off.
Remember to replace the filter as soon as possible to ensure optimal performance of your air purifier.
I hope these stepa can help you further.
Kind regards
