20 Most Recent
Ricoh Aficio MP-C305SPF Color Copier : C305 Questions & Answers
How to delete web password off aficio mp c305 spf?
Type in the printers IP address. If you don't know it, go to user tools, the button with a diamond shape and a 123 on it. Go to system settings and then interface. Press the print list. It will give you 3 pages, only the first page is important. Search for IPv4 and type that into your web browser. The login details are admin, admin.
Sc 285 sur un photocopieur ricoh
You either have a torn ITB belt or a faulty ITB belt unit.
If this is not your problem then you could have a faulty ID sensor or a faulty PCU that is causing your Process Controll to fail and generate the SC285.
How can I fix a malfunctioning Ricoh 3410 printer?
On this page see error code 542.
Error Codes > Ricoh > SP3410DN > page 2 (printcopy.info)
- Code: 542
- Description: Fuser reload error
This SC is issued if one of following conditions occurs: The fusing temperature rises 8°C or less in 1.5 seconds; and this continues 5 times consecutively. -or- The fusing temperature has not reached 45°C within 9 seconds (after the fusing lamp comes ON while the machine is warming-up). -or- The fusing unit does not attain reload temperature within 35 s. (normal temperature) or 65 s (lower temperature - the thermistor output is less than 18°C) after the fusing temperature control starts.
