20 Most Recent Konica Minolta Bizhub C284 Color Copier / Printer / Scanner Questions & Answers
Prints a black box from internet explorer
how does it print for pdf or word? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/27/2016 3:35:22 AM • Konica Minolta... • Answered on Jun 27, 2016
Scan colored paper
color orignal or color paper Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/14/2016 10:33:36 PM • Konica Minolta... • Answered on May 14, 2016
Page in negative printing from windows image browser
check the print properties and try down load latest drivers for your machine at konicaminolta Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/7/2016 10:31:15 PM • Konica Minolta... • Answered on May 07, 2016
Bizhub284 prints but there is no ink on paper
all colors? check the sponge looking roller right side door in correctly, check print try to catch the printer in doing a job open the right side during a job is there toner on the transfer belt across from the sponge roller. does this happen during copy does demo page and meter count page come out ok, try different file also and program pdf or web page etc. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2015 2:39:09 AM • Konica Minolta... • Answered on Dec 30, 2015
Equally spaced lines across page only on color copies
If not in the direction of the paper feed then in the direction of the scan head. Dirt on the scan head or bad scan head or scan head connection. Send it back.
4/8/2014 4:36:21 PM • Konica Minolta... • Answered on Apr 08, 2014
PCL XL Error Konica Minolta
try re-installing printer driver - see if any more up to date printer driver exists for the operating system ? and the printer model number ?
10/19/2021 4:54:07 AM • Konica Minolta... • Answered on Oct 19, 2021
Konica minolta bizhub 363 power on light no display not booting process
I encounter same problem i test the Operation Board and its fine when i replaced the PWB- MFP Assy. Part number A1UDH02102 and it works! The display came back.
8/25/2021 7:11:41 AM • Konica Minolta... • Answered on Aug 25, 2021
Caution Maintenance CAll M2 Call Service Konica Minolta bizhub 185
Maintenance call (m2) call service
8/18/2021 6:57:04 AM • Konica Minolta... • Answered on Aug 18, 2021
Konica minolta bizhub 601 warming up option donot show ready to copy
Sir/Mam, Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
8/9/2021 12:33:08 PM • Konica Minolta... • Answered on Aug 09, 2021
We have two Konica Minolta (Develop) c203s which won't boot up. Both working fine one day, then overnight seems to have frozen. I.e. Turn of the main power switch, the two status lights (Orange and blue) on the front of the machine will light up and stay on. Theorange light aroundthe "go" button will light up. But nothing else
Try to Troubleshoot By SWITCH ON MACHINE FROM MAIN POWER SWITCH BY PRESSING UTILITY BUTTON. -WAIT AND KEEP HOLDING UTILITY BUTTON -AFTER 10 TO 15 SECOND, TROUBLERESET OPTION WILL APPEAR ON SCREEN, TOUCH IT AND SWITCH OFF. -NOW ON NORMAL WAYS. if not ok, then check the panel connection. - after switching off and on, wait and observe if it display KONICA MINOLTA SCREEN OR Hour Glass symbol. and let me know for further diagnostic.
8/6/2021 2:50:06 PM • Konica Minolta... • Answered on Aug 06, 2021
How to solve error code c2552 in konica minolta
C2552 generally shows Cyan Developing poor toner ratio... Please let us know Which Model??
7/11/2021 6:46:14 PM • Konica Minolta... • Answered on Jul 11, 2021
How do i resolve the issue of Konica Minolta Error Code C0202?
The error code C0202 indicates paper jamming in tray 1, C-O204: Tray-2, C-0206: Tray-3, C-0208: Tray-4. First of all, power off and unplug your copier, then empty paper from the problem tray and from the tray below it. Take out the problem tray, now you can see a paper jammed.
how to fix trouble code C-0202 error code in Konica Minolta ...
Videos as well https://www.google.com/search?q=Konica+Minolta+Error+Code+C0202 ..
6/25/2021 3:31:12 PM • Konica Minolta... • Answered on Jun 25, 2021
2answers
How do i reset the error code c4641 in konica minolta bizhub c8000
Check the yellow drum sensor and developer unit. Per service manual:
  1. Output the test pattern to check whether the uneven density occurs on Y toner area.
  2. Check the intermediate transfer belt, and clean/replace it if there is toner image or damage
  3. CAUSE: The histogram processing of the Y toner has terminated abnormally on the color registration sensor /Rr (PS85).
6/25/2021 5:13:58 AM • Konica Minolta... • Answered on Jun 25, 2021
2answers
I forget service mode password in konica minolta bh 501 can you help me
There is only 3 service mode password the easiest way to find it try the 2 and the other 1 tomorrow so it will not lock. 1) 11111111 2) 00000000 the last 3) 12345678. You dont have to go to [Utility] ... etc its a long process w/c you can see the service mode password/ change.
3/16/2021 2:34:05 PM • Konica Minolta... • Answered on Mar 16, 2021
2answers
Konica Bizhub 211. What does error code C0000 mean?
The code means there is some problem that requires a service technician to solve.
2/14/2021 3:29:40 PM • Konica Minolta... • Answered on Feb 14, 2021
2answers
I am mohamed hussein in somaliland using konica minolta 364e problem I had is paper jam and fusing unit is extremely hot
The fuser runs hot. Clear the paper jam and all should be good.
2/8/2021 4:34:18 PM • Konica Minolta... • Answered on Feb 08, 2021
Konica Minolta Bizhub C284 Color Copier / Printer / Scanner Logo
8 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
George Mclaughlin
Ekse
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
prints black box from internet explorer
  • Office Equipment & Supplies
