20 Most Recent Konica Minolta Bizhub C224 Color Copier / Printer / Scanner Questions & Answers
enter service mode
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Nov 12, 2019
the file may be corrupt try different files
Konica Minolta... | Answered on May 07, 2017
what color are the stripes
Konica Minolta... | Answered on Mar 11, 2017
1234567812345678
or
12345678
Konica Minolta... | Answered on Aug 08, 2016
check the transfer belt and transfer roller
Konica Minolta... | Answered on Jul 03, 2016
replace the fuser unit
Konica Minolta... | Answered on Jun 25, 2016
prints ok from a different tray????????????????????
Konica Minolta... | Answered on Jan 18, 2016
does happen when copying does the demo page print ok does the meter count page print ok.? if you print in b/w is it ok?
Konica Minolta... | Answered on Jan 15, 2016
run gradation test, ensure fuser is at correct temp via media thick 1 thick 2 etc paper
Konica Minolta... | Answered on Dec 29, 2015
MFP Board
Memory Board/1
Memory Board/2
EIF Board IC-414
Dual Scan Image Board
One of the boards is bad. Recommended that you have a qualified Tech look at the machine. Also might need to have the firmware upgraded. via Secure KMBS web site you can not get. The code is a abort code!
One of the followinf
Konica Minolta... | Answered on Oct 31, 2015
you may find in internet just type model and you get it
Konica Minolta... | Answered on Sep 29, 2015
Well you hit the "Jack Pot" That code means some one attempted to COUNTERFIET UNITED STATES currency!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!. Some one is in big trouble, There is not a thing you can do. You must get a KONICAMINOLTA Technician out to remove a special chip located inside the machine. It will be sent to KONICAMINOLTA then to the US SERECT SERVICE, since they protect US Money. Once a determination is made as to what happen. A new chip will be issued and new software will be up loaded. UNTIL THEN THERE IS NO RESET!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Konica Minolta... | Answered on May 21, 2015
In order to enable this function, you will need AU-101 / AU-102 Biometric Finger Vein Authentication Device. These biometric finger vein readers connect directly to the MFP and work in conjunction with the machine's internal authentication capabilities, or integrate with Konica Minolta's PageScope Enterprise Suite.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta... | Answered on Aug 21, 2014
its a warning p- errors tell you that a consumable is reaching its life such as fuser iu or transfer belllt
Konica Minolta... | Answered on Aug 18, 2014
Check your separations preview, (>Window>Output>Separations Preview). Most likely the colors you have set up are not correct. You will need to identify the problematic colors and address them within your swatch palette. Very common problem.
Konica Minolta... | Answered on Dec 26, 2013
The Printer Is In An Error State also appear in more wrong with the all inappropriate printer driver and also need to renew the driver to retaliate problems of this kind. You can handle the best way and deal with the drivers is easier. Then, the driver is easy and more intuitive to recognize with your system and find out the all correct drives. You can access to need about the specific system your computer is running.
Reasons that cause Printer Is In An Error State:-
1. Perhaps the drivers are not installed correctly.
2. Indicate if you have downloaded the drivers and software relating to your printer model.
3. Attachment issues can also be the root of this printer error state issue.
4. BIOSS issue is a very simple factor in giving rise to this daunting issue.
5. Perhaps the wires or USB wires are not attached well.
Just follow the steps which are mention on the blog to fix the Printer Is In An Error State. We give online help for Any problem in printers our Call us on TOLL-FREE NUMBER in our BLOG.
Konica Minolta... | Answered on May 29, 2020
Konica Minolta Bizhub C224 Color Copier / Printer / Scanner Logo
21 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
bizhub c224
  • Office Equipment & Supplies
