20 Most Recent Prague Sunray 49025G Questions & Answers
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Prague Sunray... | Answered on Mar 06, 2010
Did you find a solution? If so please provide contact info, would be much appreciated.
Prague Sunray... | Answered on Nov 05, 2008
mcdevito75 here, It may be, best bet is to contact Prague watches at www.WatchesOutlet.com online. Once at page, left side of page click contact us and email them with your watches info.
Prague Watches | Answered on Sep 21, 2010
Contact Time Track Services directly and explain the problem to them. They will be able to help you sort another form of payment. They will also appreciate you took the time and effort to warn them.
Watches | Answered 2 days ago
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Watches | Answered 3 days ago
First, reset the clock to 0:00 hours. The instant the clicking stops, pop out the battery. The second hand stem should be at 0:00 hours. The front cover can only be removed from the bottom. Put both thumbs at the bottom of the font cover and push inward, but not too forcefully (Junghans stopped selling replacement covers shortly after dropping the product line and they are nearly impossible to find). The center should lift up enough to slide a thin credit/promotion/gift card under the center tab on the bottom. Then work the card up either slide to disengage the other four tabs. The five tabs are located at the bottom center, one each on both straight sides alligned with the top of the digital display, one at 7.5 minutes, and the last one at 52.5 minutes. That is easy part. Now comes the hard one You then need to glue the second hand back onto its stem. Superglue (cyanoacrylate based) works best. The second hand must be attached perfectly level or it could scrape the cover, the clock face, and the other hands as it rotates on a tilt. Practice a few times before applying the glue. You will notice that the socket on the second hand fits the stem very loosely. Once you are ready to glue, apply one drop of superglue on the second hand socket and mount it on the centermost stem and hold it perfectly still and in proper alignment and steady for a minute or so for the glue to set. Once the glue dries, put the battery in and let it run long enough to determine if the second hand is in correct alignment. Remove the battery again. Make certain the clock face is completely free of dust and dirt before reattachment of the cover. Insert the cover from the top down snapping the five tabs into place. It may be necessary to reverse the removal process. Then you can reinsert the battery. The process worked for me when mine was accidentally knocked onto the carpet and the second hand was detached from the force of the impact. In fact, I can no longer tell which one I performed the repair on.
Watches | Answered on Sep 27, 2020
Visit the website.. You will find the instructions
Watches | Answered on Sep 24, 2020
I need the manual for Invicta Reserve 6207
Watches | Answered on Sep 13, 2020
This suggests one of three alternatives are at play: 1) You don't have the manual to the watch and thus don't know the sequence to turn off the alarm n chime; 2) You have the manual and it is inaccurate. 3) The watch is defective.
https://www.amazon.com/ask/questions/Tx3VS2PTPQUSRAG/
Watches | Answered on Aug 24, 2020
Prague Sunray 49025G Logo
Popular Tags
3 questions posted
Popular Products
Top Prague Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Prague Watch Expert? Answer questions, earn points and help others
View Most Popular
Prague Watches
  • Prague Watches
Most Popular Question
self winding prague mens watch will not
  • Watches
