20 Most Recent American Standard Colony Hydro Massage Bathtub Only AME Questions & Answers
2answers
I broke the pvc pipes
the PVC pipes used to plumb bathtubs can be either rigid PVC pipe or flex PVC pipe. You may use either kind and is usually available at your local Home Center.
4/10/2015 4:19:08 PM • American... • Answered on Apr 10, 2015
2425elho020
You will need to check with the Mfg of your bathtub for new skirt.You may find a generic front skirt at your local hardware store i.e. Lowes or Home Depot.US Parts Center
9/4/2013 6:01:54 PM • American... • Answered on Sep 04, 2013
0answers
0answers
I need to buy 2
Be the first to answer 7/25/2011 1:24:50 AM • American... • Posted on Jul 25, 2011Be the first to answer
0answers
There was no owners manual
google its online it should show u
6/3/2011 3:00:01 AM • American... • Answered on Jun 03, 2011
How many days in a year ?
365!
What about your bathtub?
2/17/2011 4:34:05 PM • American... • Answered on Feb 17, 2011
0answers
My pump will not work
The pump is damaged or there is heavy clogging within that prevents the motor to work.
If there is wearing of the pump bearings or bushes then the rotors might get struck resulting in the hum. Secondly check the CAPACITOR connected to the motor , if the capacitor is tested and shows low value then you can replace.- simple test is to charge on the mains and see if there is retaining charge to prove it works. If not replace.
Finally remove and clean the motor and pump assembly.
2/2/2011 5:52:51 AM • American... • Answered on Feb 02, 2011
One of the "Air Volume Control" valves shoots
you can change out the complete air control valve. One thing i would have you do before changing that out is to make sure all of the jet faces are turned on. to do this turn the face of the jet clockwise. this will let the maximum amount of water come out of each jet face.
Sometimes if there are adjustable jets in the tub and they all get shut off, it will force the water that should be coming out of the jet faces back through the system and out the air control knob if it is open.
Just to check. that may not be the case....but...that would be cool if it were.
1/25/2011 6:07:29 AM • American... • Answered on Jan 25, 2011
Tip toe drain can not be close to keep the water
try turning it so it will drop
1/19/2011 5:01:07 AM • American... • Answered on Jan 19, 2011
The jets on the right side have very poor pressure
check to make sure the jet faces are turned on. some model tubs have adjustable jets that you can turn the face of the jet off.
1/13/2011 3:57:18 PM • American... • Answered on Jan 13, 2011
It appears that one of the jets is leaking. How
One of the quick ways to fix leaks at jets is by using Millaput two putty resins mixed and worked round the outside of the defective jet.
f there is a threaded nut on the back of the jet, undo the nut as much as possible and push the jet out into the tub. Spread aquarium grade silicone around the jet and push back into the hole, put more silicone in front of the nut, you may have to spread it in the small area with your finger or if you can squirt it in from the tube of silicone. If there is no threaded ring on the backside of the jet, go to the jet in the tub and looking down on the jet, turn it to the right. It should pop and pull out of the housing. There will be a retaining ring that may require a special tool to remove it, once the ring is out, clean it very well, spread silicon on the threads and the lip. Reinstall in the hole, reinstall jet wait 24 hours and fill and test for leaks. Take you time and you will not have to do it over again. Check where the leak is coming from, sometimes there is a hairline crack in the jet assembly, if this is the case, make sure the area is dry then use a 2 part epoxy for plastic (from lowes or home depot) and smear this all over and around the crack, let dry 24 hours, fill and test.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
9/11/2010 8:10:51 PM • American... • Answered on Sep 11, 2010
Air switch randomly comes on by itself and I have to leave the breaker off
This could be caused by a faulty relay or switch in the control panel. It is best to have a qualified technician inspect the control panel and replace any faulty components. If the issue persists after replacing the faulty components, then it could be a wiring issue and a qualified electrician should be consulted.
2/22/2023 9:40:24 PM • American... • Answered on Feb 22, 2023
American Standard Colony Hydro Massage Bathtub Only  AME Logo
Popular Tags
22 questions posted
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Home
Most Popular Question
pump will not work
  • Home
