20 Most Recent Salton RA14 14-Cup Rice Cooker Questions & Answers
You can order Salton replacement parts by calling their toll-free number at 800-233-9054. You can also contact them via the Customer Care section of Salton's website. http://www.salton.com/
Salton RA14... | Answered on Apr 25, 2011
Maybe, but look inside the cooker with the pot removed and check the button in the center....make sure that it will spring back up after you push down on it. If it is stuck in the down position the cooker will stay on high cook and not go to warm....
Check if something is stuck in it and get it out if there is anything there so that the button will freely move up and down...
If that is working well then it could be the t-stat...
heatman101
Salton RA14... | Answered on Jan 29, 2011
Dear Rekha.
It seems to be heating coil burned.Do you smell anything odor.
Salton RA14... | Answered on Jan 10, 2011
mcdevito75 here, Most of these cups that come with these machines are measured by the standard 8--10 oz. standard cup. but to be sure here is Saltons contact, email only [email protected]
Salton RA14... | Answered on Jul 11, 2010
Any chance you could post a photo? Often these machines have a deflector that reduces the heat applied to the middle of the pan - it sounds as if that is the item you are talking about - there may have been a small ceramic ring or block that the screw went through which would put it a little above the element or a little below the pan base. look in the floor beneath the element for screw holes. Hope this helps - if not please post again, with photos if possible :)
Salton RA14... | Answered on Mar 23, 2007
Contact Salton directly to inquire/
Salton Kitchen... | Answered on Nov 12, 2020
Press the Brown button with the lid off before pressurizing. The Power Cooker PRO has a brown button for saut?ing. On the Power Pressure Cooker XL press any preset buttons with the lid off to saut?. These units have a Slow Cook feature with low pressure.
http://www.salton.co.za/instruction-manuals/630_SEPC01_Salton_Electric_Pressure_Cooker_Instruction_Manual.pdf
Salton Kitchen... | Answered on Mar 15, 2020
Did it not come with a user manual? Sugar goes in the top next to the juice chamber. There should be a flip up lid sort of like on a coffee maker. Btw, I found a user manual online in less than thirty seconds so if you find that you need one then it should be really easy to get. I wouldn't be surprised if there are dozens of videos that teach you how to pour sugar into this machine.
Salton Kitchen... | Answered on Nov 08, 2019
I would suggest that the standby light is there to let you know that the unit is ready and waiting for you to set it and for use. Much like any appliance such as TV,s etc have standby lights. Any appliance with a standby light use a small amount of power. When not in use, its recommended to turn it off at the power point to save a bit of power.
Salton Kitchen... | Answered on Oct 11, 2019
You need to make sure the inner pot is making complete contact with the center heating element in the bottom center, and that the metal surface of the center contact is free of contaminants like oil or food particles. If this does not clear the error message you might need to replace the contact switch on the bottom of your unit. Switch replacement procedure depends on the model of your unit. Try doing a search for the repair manual for your particular model number.
Salton Kitchen... | Answered on Apr 02, 2019
There are no repair parts available. You decide what your going to do.
Salton Kitchen... | Answered on Dec 31, 2018
Salton RA14 14-Cup Rice Cooker Logo
14 questions posted
Top Salton Kitchen Appliances - Others Experts
fixzum
Level 1 Expert
ray gallant
doconnell13
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Salton Kitchen Appliances - Others
Most Popular Question
need power cord rice
  • Kitchen Appliances - Others
