20 Most Recent Toshiba CT-90366 Remote Control Questions & Answers
it cannot scan
Toshiba CT-90366... | Answered on Sep 08, 2016
Shouldn't matter what the OS (operating system) is. What you need to do is to make sure you convert the movie to proper format which would allow you to view on DVD player after burning. Usually you need a seperate software. Your DVD player should say what formats are compatible. Usually listed on unit or in manual. Avi is a great format but when you burned it to DVD your computer probably created a Data Disk. Which would make it unreadable by DVD player. Check to make sure you are able to convert to format that's readable by your player.Good Luck
Toshiba... | Answered Yesterday
It is out there, that if you have internet enabled on the Toshiba BD player, did you need to stop or disable the internet capability.
Toshiba... | Answered on Nov 10, 2019
the power led may be flashing a code you can google.
My Panny will flash the power LED when there is a problem. Well, for many problems anyway. Observe the sequence like 7 and 3. I do not know if the Toshiba has that feature. If not, the issue is most likely power, HOWEVER, any board could be at fault since it powers up then shuts down. An excessive load on another board could be shutting it down. A fault on the PS board itself could also be shutting it down.
Toshiba... | Answered on Nov 07, 2019
It sounds like the main internal power supply has gone south. Your best bet would be to take it into a TV repair shop and determine if it would be an inexpensive repair. Usually repairs on the newer TV's can run higher then replacing the TV with a newer model.
Toshiba... | Answered on Nov 05, 2019
USE ANY NUMBER HERE. CALL A SPAMMER AND HAVE SOME FUN TODAY!! ALL TOLL FREE TOO!!
THIS IS A COLLECTIVE PHONE LISTING OF ALL THE SPAMMERS HERE ON FIXYA. WE SUGGEST YOU DONT CALL ANY OF THEM UNLESS YOU KNOW WHAT YOU ARE DOING !!
1-85O-8I2-4OO9 1-8OO-8O3-1O69 1-888-499-5520 1-877-769-0969 1-888-499-5520 1-8OO-828-O294 888-348-1833 1-888-444-6538 1-855-616-7697 l-855-892-OO6O 1-888-570-9791 1-855-26O-OO64 1-855-536-5666 1-844-24O-9111 1-8OO-55O-5195 1-845-481-1722 1-855-616-7697 1-844-819-3382 1-855-221-4867 1-845-481-1722 1-800-258-1449
IF YOU KNOW WHAT YOU ARE DOING HAVE SOME FUN WITH THESE LOSERS.. CARRY ON7
Toshiba... | Answered on Nov 03, 2019
If your TV is connected to the internet, firmware will be
automatically made available.
If your TV is not connected to the internet, you can download the latest version of firmware from www.toshiba-om.net/firmware.php
www.toshiba-om.net
If you are still having problems contact the Toshiba Helpline on 0333 222 7111
http://www.toshiba-om.net/pdf/manuals/lcdtv/English/Country_Specific/L2436-4050-English-Specific.pdf
Toshiba... | Answered on Nov 02, 2019
Open internal fuse or power supply failure
Toshiba... | Answered on Oct 31, 2019
THERE IS NO RESET GO SEE A LOCAL REPAIR SHOP
Toshiba... | Answered on Oct 27, 2019
You need to check in sound sitting and make sure the audio is set to be from tv not amp
Hi Upul73879, indicates Toshiba TV model, what are you commenting on and what do you want to connect it to, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Upul73879, indica modelo del TV Toshiba, que estas comentando y a que quieres conectarlo, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Toshiba... | Answered on Oct 26, 2019
Toshiba CT-90366 Remote Control Logo
Popular Tags
9 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba ct 90366 scan feature
  • Televison & Video
