20 Most Recent
American Bath Cast Iron Slipper Wintess Bathtub ABF-B3-1600-WW-DM7 Questions & Answers
Fitting stand alone bath taps
These are normally connected with a chrome waist & overflow assembly that passes down into the floor where it connects into the plastic piping with the use of an 1.5" trap adapter.
All that can be seen on the finished product is the chrome parts.
Error
wrong category, sorry
A slow daring dathtub
put a part fill in the tub( about 1" deep) with the plug attached to a bit of wire
pour about 1/4 cup of draino ( sodium hypochlorite ) into the water and stir with a broom handle or suitable stirrer pul the plug out and the mixture will dissolve any hair, soap and grease that is blocking the system
NOTE
SODIUM HYPOCHLORITE IS CAUSTIC ( BURNS THE SKIN AND EYES ) SO USE RUBBER GLOVES AND SAFETY EYE WARE AND USE EXTREME CARE
FLUSH THE BATH WELL WHEN DRAINED
Install whilpool tub steps
Generally I will make the entire front skirt of the tub removable. You need to make sure your access is located so that you can remove the pump if necessary.
Access to the plumbing is advisable also but usually not required by code as it can be serviced from the top side. I am a licensed bath contractor and available to help with any problem you may encounter through premium service or live chat. I can save you many hours of frustration and 100's of dollars on this project.
Angle base cracks in factory seams
contact manufacture ask for replacement as it is most likley defect substandered matriels thay may be intrested in the fault in there product and may give you discount on new if you use there product again.
thank you for useing fixya please rate me
What are the different types of powder coating?
Thermoplastic and thermoset are the two types of powder coatings used by leading
Powder coating services. Thermoplastic coating don't undergo any chemical change when heated. Therefore they can be softened and hardened by heating repeatedly. Unlike thermoplastic coatings thermoset coatings changes into infusible materials on heating. Nylons and vinyls are thermoplastic while acrylics and polyesters are thermoset.
4/24/2024 12:02:34 PM •
Home
Answered
1 hour ago
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
on Apr 16, 2024
Lost half of my jets on one side of the tub only.I have tried closing the jets that do work half,does not make a difference to the jets not working.Would it be best to empty the tub and start over?
it's likely due to an air lock. Here's what you can do to resolve this issue:
Manually Clearing an Airlock:
Run the jets on low for about 30 seconds.
Then run the jets on high for another 30 seconds.
Repeat this process 3 or 4 times.
If you hear a gurgling sound and see air bubbling up, continue running your hot tub until it pushes all the air out.
If this doesn't work after several attempts, try a different approach.
Bleeder Valves or Pump Method:
Some spas have bleeder valves that allow you to bleed air out of the lines.
First, turn off the spa at the breaker.
Access the pump and loosen the valve to allow the air to escape.
When the air has bled out (you'll notice it turns from hissing air to a stream of water), close the valve.
Run the pump to ensure the jets are now pumping water as expected.
Why Are the Jets Not Working on One Side Only?:
Many hot tubs have two water pumps.
If the jets on only one side of your hot tub stop working, there could be an airlock in only one of the pumps.
It could also be a blockage in the jet lines for that side or a problem with the internal mechanism of the jet itself.
Can You Use a Spa with an Airlock?:
It is not recommended to use a hot tub with an airlock.
4/3/2024 4:33:08 AM •
Home
Answered
on Apr 03, 2024
Restarting my marcel hour strike quartz clock nrms603.
To restart your Marcel Hour Strike Quartz Clock NRMS603, follow these steps:
Stop the Pendulum: Gently stop the pendulum from swinging by holding it still.
Remove the Battery: Open the clock case and locate the battery compartment. Remove the existing battery.
Wait for a Minute: Leave the clock without a battery for about a minute to allow any residual charge to dissipate.
Insert a New Battery: Insert a fresh battery into the compartment, ensuring the correct polarity (usually marked on the battery holder).
Start the Pendulum: Gently release the pendulum and let it start swinging.
Set the Time: Use the clock's time-setting knob or buttons to adjust the time to the correct hour and minute.
Your clock should now be restarted and keeping time accurately
4/3/2024 4:30:05 AM •
Home
Answered
on Apr 03, 2024
