20 Most Recent
Olevia 37" 237-t11 1080i widescreen hdtv lcd black Questions & Answers
Why won't my TV scan for channels
Possible causes for this are:
-your tuner is broken
-antenna cord is not connected correctly
-does your tv support your source (cable, sat, etc...)
it is a bit old model so you may need a setupbox to tune the channels.
If you can pin point the problem it seems that ebay has a lot of spare parts for that model.
TV light wont turn on or TV won't turn on
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Tv won't come on blue flashing light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "
Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Tv
Check and replace damaged component/s at its main power supply regulator [SMPS] board, or replace this board as card basis. This is not the fault with the remote control. It is with the TV itself. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Can an Olevia HD TV from 2005 accept a HD antenna? How do I change the settings to recognize the antenna source? Model 247FHD-T11
I am guessing but there is little difference between a normal antenna and one supposedly intended for HD reception.
Successful tv performance when HD channels are selected from the line up of available channels is dependent on receiving a strong high quality signal and if you are located in the right place in relation to the transmitter, something like a wire coat hanger will be enough but the greater the distance and/or the more difficult the local geography the better designed and higher performance antenna will be required.
Antenna manufacturers aren't embarrassed about making misleading marketing claims. To the best of my knowledge there is no physical difference between an ordinary tv antenna and a so-called HD antenna, the latter would be better designed, higher quality, higher performing and more expensive. Choosing the right antenna for your immediate area is difficult and it is best to take the guesswork out by asking a reputable local antenna supplier and erector. The best quality coaxial cable will also be required.
My tv doesn't have any means to select a type of aerial - a HD picture is displayed when a HD channel is selected. If your tv has such a selector it will undoubtedly be found in the menus...
I have picture but no sound on my olevia 227 s11
Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit.
