20 Most Recent Sanyo SR-4911M Compact Refrigerator Questions & Answers
the unit should have heat coming off the condenser coils on the back. some of the units have a little fan motor to help cool the condenser. make sure there is plenty of space for air flow around the unit, as this is crucial to normal operation.
Sanyo SR-4911M... • Answered on Jul 12, 2012
it shouldn't be gurgling, has it been laid on its side at some point? anyway,, sounds like it has air in the system,, unplug it and let it stand upright for 24 hours, if the problem still persists,, it may need to be charged, the compressor getting hot is normal , if its very very hot, its because its running constantly trying to cool the unit
Sanyo SR-4911M... • Answered on Jul 04, 2011
make on thermostate and check compressure working or not
Sanyo SR-4911M... • Answered on Dec 01, 2010
remove shelves and insert keg.
Sanyo SR-4911M... • Answered on Feb 03, 2010
The fan shuts off when you open the door. It's controlled by the door switch. open the door and look for the door switch, push it in and the fan should come on.
Sanyo SR-4911M... • Answered on Sep 10, 2009
Hi, it's possible,your motor overlay relay has switch off motor, if your days are hot, or if room temp get high, that could happened,unplug ref. let motor cool down for about an hour, if compressor is running, but not cooling, it's possible you got a freon leak, normally ref have a condensate line, that passes through, front of door, that usually get rusted and leak,normally we by-pass it, now if there's a leak, you will have to repair leak first, you will have to change filter drier, vacuum and recharge. no you won't be able to buy freon and tap it up, same princple like vehicle a/c, but, different application, could also be an electrical problem, check motor overload, situated on compressor terminal, remove compressor terminal cover, and you will see overload relay, it's round, has one wire connected to compressor terminal and another connected to wiring harness. also, you can check compressor for short circuit, remove 3 wires from compressor terminal, place one tester lead on copper tubing coming from compressor and next tester lead, place on compressor terminal one by one, if you hear a beep (continuity) from any one of those terminals, compressor windings are faulty, replace compressor, or could just be hot summer months, let it cool down, but remember, remove plug from receptacle. or you are victim of low voltage, low voltages are more frequent in summer months, it could damage compressor winding, or compressor overload relay, let it cool down, and retry it. let me know what happened, before you attempt any repairs. and i can tell you what exactly what the problem are. good luck.
Sanyo SR-4911M... • Answered on Aug 12, 2009
The thermostat is bad, replace.
Sanyo SR-4911M... • Answered on Mar 09, 2009
Sounds like you checked for the proper items, fans to move cold air, etc. and if stuck in defrost mode. If the compressor is running you would have to be cooling unless... the refrigerant has leaked out. And that is basically a bad thing. If in defrost cycle the compressor would stop while defrosting soooo it's looking like the refrigerant is gone. Can you take the back interior panel off to see if the coils have a full frost pattern?
Sanyo SR-4911M... • Answered on Jan 05, 2007
Appliance bulbs can be purchased at any home improvement store.
Sanyo... • Answered on Mar 09, 2021
try unplugging thermistor if gets cold replace it if no bad compressor or low freon
Sanyo... • Answered on Feb 28, 2021
I searched the internet and did not see a manual mentioned online. So, you may wish to contact vendors on the internet to ask if they have a manual. FIXYA is a free internet service and does not sell or mail products, and is designed for do it yourself (DIY) repairs. Examples: https://asianhomeappliance.com/home/detail_item/1919 https://www.carousell.ph/p/sanyo-sr-8k-2-7-cu-ft-personal-refrigerator-1012406429/?t-id=y8IePVwZ9Q_1592137710716&t-referrer_browse_type=search_results&t-referrer_request_id=zjJftFk9povRDeMo&t-referrer_search_query=Sanyo%20SR%208k&t-referrer_sort_by=popular https://www.carousell.ph/p/sanyo-sr-8k-2-7-cu-ft-personal-refrigerator-1012406429/?t-id=y8IePVwZ9Q_1592137710716&t-referrer_request_id=39Cbg_ZLkMBwQuZn https://ph.priceprice.com/SANYO-SR-8K-15611/ In the Philippines, Sanyo folded into Panasonic and Haier, so it is possible that they might provide assistance in that country, although I did not locate that model information on the internet. https://panasonic.net/sanyo/ph/cs/
Sanyo... • Answered on Jun 14, 2020
https://www.made-in-china.com/cs/hot-china-products/Thermostats.html?gclid=EAIaIQobChMIibi_5Zyu5wIVF-DtCh3yogsREAAYASAAEgJC0vD_BwE https://www.alibaba.com/premium/thermostat_for_sale.html?src=sem_ggl&cmpgn=2069025735&adgrp=80538884390&fditm=&tgt=kwd-308834881422&locintrst=&locphyscl=1011086&mtchtyp=b&ntwrk=g&device=c&dvcmdl=&creative=374874816229&plcmnt=&plcmntcat=&p1=&p2=&aceid=&position=&gclid=EAIaIQobChMIibi_5Zyu5wIVF-DtCh3yogsREAAYAiAAEgL2uvD_BwE
Sanyo... • Answered on Jan 31, 2020
Sanyo SR-4911M Compact Refrigerator Logo
24 questions posted
Top Sanyo Refrigerators Experts
Lawrence Oravetz
NOEL
NOEL
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Sanyo Refrigerators
  • Sanyo Refrigerators
Most Popular Question
mini fridge not cool fridge doesnt
  • Refrigerators
