20 Most Recent Haier YL-HD01 Remote Control AC-5620-085 Questions & Answers
start by trying to reset your TV. Disconnect the power cord from the outlet, then press and hold the power button on the TV (not the remote), for at least 10 seconds. Then wait a few minutes and plug the TV back in and press power once. 2 blinks on Samsung TV's usually indicates a bad power supply.
Haier Televison... | Answered on May 14, 2020
Here is a question that we see often.
Question:
I've replaced everything in my television because it previously had a black screen with no lighting. Now it doesn't turn on at all and all I have is audio. What could be the cause ?
So your television stops working properly and you think it must be easy to fix, because you can buy boards on eBay, and you can watch YouTube videos. So you make a decision, you buy a board and you fit it, but the television still doesn't work! This is a classic case of the 'let's try replacing this' method of television repair and illustrates why it is a bad idea. It doesn't work for a number of reasons. To correctly diagnose issues, you need to know every board, what is does and every component on the board. You need to know which part has failed, replace the component, or replace the board. The parts you purchased off eBay were probably out of scrapped sets and not tested. The part your put in was dead when you put it in, so you just moved on to another guess at what might be the cause and replace a board that is fine. And so it goes on, you change all the boards and it still doesn't work. Did you notice the large print that says 'No Refunds, NO Returns'. This is to stop you sending your old one back and saying it didn't work, but the unscrupulous use it as an excuse to get money for selling items that may not work! The course to be a television engineer is 2 years full time education, take it to someone that knows how to diagnose and fix. It is by far the cheapest option. The part that failed might be a 20 cents fuse diode hard soldered to a board. They will charge you $2 parts and an hours labour.
Haier Televison... | Answered on Jan 28, 2020
Hi Enno-
I found this youtube video regarding programming Bell Fibe remote if you don't know the right code for your TV.
https://www.youtube.com/watch?v=WTI0UcbCc6g
Hope this helps.
Haier Televison... | Answered on Jan 09, 2020
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/..
Haier Televison... | Answered on Dec 15, 2019
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Haier Televison... | Answered on Dec 08, 2019
go into picture set up see if on double picture
Haier Televison... | Answered on Nov 05, 2019
Use code search on your Arris URC to find something that works. If a search through all codes contained in the URC fails, try a different one.
Haier Televison... | Answered on Oct 28, 2019
Thomas,
Most Haier tvs use the same platform or menu for adjusting the settings for the tv picture. This link at bottom is for a different Haier tv but the directions should still work
Haier Televison... | Answered on Oct 07, 2019
If you are a repairperson the audio board can be found on e-bay to fix it. If you are an owner check the speaker connection on the unit as someone may have misplugged the speaker cable. Also check setup under audio and select internal speakers.
Haier Televison... | Answered on Sep 24, 2019
Unlikely. You could wind up turning the A/C on and off whenever you changed channels. Not a good arrangement.
Haier Televison... | Answered on Aug 25, 2019
be sure you have power ( voltage) from the power supply to inverter boards. If not suspect power PCB part# 8142132110050 available from Encompass for @ $115.00. if that voltage is present suspect invert PCBs which are part of the panel & is No Longer Available part# 8137751900202.
if inverters are bad you might try to research possible availability by researching individual part # from the boards themselves to see if you can find any availability. possibly from partsandproducts.net. They list about 5369 various numbers
Haier Televison... | Answered on Jul 14, 2019
Haier YL-HD01 Remote Control AC-5620-085 Logo
0 questions posted
Top Haier Televison & Video Experts
Eric Rotmil
Eric Rotmil
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Televison & Video
Most Popular Question
haier 42hp25bat picture but no sound
  • Televison & Video
