20 Most Recent Sanyo EM-S9000 Microwave Oven Questions & Answers
Why won't the vent setting program?
Please re-post your question in clearer terms. Your random arrangement of words makes no sense. Thanks!
5/24/2014 10:21:34 PM • Sanyo EM-S9000... • Answered on May 24, 2014
Is there a way to
Hey, there is a product by simple green called Simple Green BBQ & Microwave Cleaner & Degreaser, shouldn't cost you more than 7 dollars.optimuskem.jpg
5/6/2011 2:33:49 AM • Sanyo EM-S9000... • Answered on May 06, 2011
Faulty microwave oven
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
4/19/2009 5:18:50 AM • Sanyo EM-S9000... • Answered on Apr 19, 2009
0answers
Sanyo EM S8000-w microwave range quit..fuse?
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
12/17/2007 5:10:55 AM • Sanyo EM-S9000... • Answered on Dec 17, 2007
Where can I find the 3 1/4" x 10" through the wall ducting?
I would suggest a home improvement store such as Builder's Square, Lowe's, Home Depot, etc.
Otherwise, maybe local heating and air conditioning companies can point you to a source.
12/13/2007 2:44:10 AM • Sanyo EM-S9000... • Answered on Dec 13, 2007
Sanyo EM-S3650W/V
Good
7/20/2024 6:12:24 PM • Sanyo Microwave... • Answered on Jul 20, 2024
Sanyo BPL Microwave oven BMC 900T. I require a Touch panel for it.
Question edited for clarity. Question moved from Cell Phones category. Bangalore. https://www.google.com/search?q=Sanyo+BPL+Microwave+oven+BMC+900T+parts+India ..
12/7/2023 5:35:59 PM • Sanyo Microwave... • Answered on Dec 07, 2023
My Sanyo model EMO-V6. What does 'U 50' on the display mean please?
Question edited for clarity. Question moved from Sanyo Audio to Sanyo Microwave. Page 41 of the Manual refers You didn't press any buttons within 1 minute of closing the door. https://www.manua.ls/sanyo/emo-v6/manual?p=41 ..
10/25/2023 5:03:15 PM • Sanyo Microwave... • Answered on Oct 25, 2023
What year was the Sanyo Super Showerwave Microwave manufactured? model EM-P671W
It appears to be in this newspaper in July 1999. It is a very little known model. https://www.google.com/search?q=sanyo+super+showerwave++%22EM-P671W%22 ..
1/23/2023 8:17:06 PM • Sanyo Microwave... • Answered on Jan 23, 2023
Sanyo 1100 watt microwave just stopped working what happened?
It broke, but you might be able to reset it it, Remove the mains plug and count to 63 in seconds. Then plug back in. If that doesn't fix it, this is the next step. https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
9/8/2022 3:57:59 AM • Sanyo Microwave... • Answered on Sep 08, 2022
My Sanyo Microwave does not heat up
As it is an older model, I would suspect the magnetron and or capacitor. Maybe the fuse has blown but it will happen again if you just replace it.
6/18/2022 10:25:40 AM • Sanyo Microwave... • Answered on Jun 18, 2022
Where can I get my door fixed
I would find someone that repairs and fixes small appliances then. I would search on Google and Yahoo small appliance repairs then.
5/19/2022 5:46:24 AM • Sanyo Microwave... • Answered on May 19, 2022
2answers
Sanyo EMC5796V microwave. "Sanyo Lever". Possible part number reference I can find is 3772983pm.
That is called the door catch. Try espares.com or a Sanyo microwave repair centre for spares.
4/6/2022 5:27:01 PM • Sanyo Microwave... • Answered on Apr 06, 2022
I have a Sanyo Showerwave EM-P672W microwave, that just stopped. Went to heat something up, soon as I went to start it, poof. At the time, it was only about 4 yrs old, & was working fine. I do live in a building that is very, very prone to power surges & fluctuations. Can't count the number of times I've plugged in the vacuum, or used the a/c or garbage disposal, & either had a breaker pop or a safety outlet pop it's mini breaker. I am guessing the microwave has blown a fuse in it due to the power issues? Wanna get another opinion before I bother diving in & getting a new fuse ordered. I do pc tech work, so I am well aware of the dangers working with caps & power supplies.
Mains borne power surges and transients are dangerous to semiconductor devices and especially CMOS devices - any equipment containing these should be provided with surge protection and because almost everything is a computer these days, this means almost everything! Regarding microwaves - I have been inside quite a few but so far haven't noticed any fuses protecting the control circuitry though there is usually one in the eht circuit. A power surge is unlikely to harm the components of the eht side. The voltages of the control and timer circuitry are quite normal but those of the eht side are beyond the scope of the ordinary multimeter. I don't have an eht probe so I have never measured it but at various times I have read the voltage is anything from 2000 to 7000 and because it is mostly transformer generated, it is exceptionally dangerous and if the discharge resistor is absent or not working the capacitor can be dangerous for a long time after it has been switched off.
12/5/2020 10:45:55 AM • Sanyo Microwave... • Answered on Dec 05, 2020
2answers
I have a Sanyo Microwave EM-2500T, serial number 508650448 and I need to know the maximum wattage of it please. It was given to us second hand 23 years ago and is still going strong!
Hi Alison!Wow. That microwave certainly doesn't owe you anything. Nice work on 23 years.While not able to come up with the exact specifications or owner's manual, I would guess that 850 to 1000 watts would be pretty close to the number for your unit, especially if it's running on a 15A breaker.Sorry I couldn't have been of more help.-Steve
10/15/2020 6:46:50 PM • Sanyo Microwave... • Answered on Oct 15, 2020
Goal: mute EMS6588S Sanyo microwave. What does the beep speaker look like? (I want to tape on it to mute)
That will not be easy - you will have to take the cover and front door panel off to get to the printed circuit board. The buzzer will be mounted on that somewhere. buzzer-undefined-undefined-0.jpg
6/12/2020 10:29:24 AM • Sanyo Microwave... • Answered on Jun 12, 2020
Sanyo EM-S9000 Microwave Oven Logo
Popular Tags
25 questions posted
Top Sanyo Microwave Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Microwave Ovens
Most Popular Question
  • Microwave Ovens
