20 Most Recent
Sharp Comfort Touch AF-R120EX Air Conditioner Questions & Answers
My sharp comfort touch air
Can work the external drive and you see that turns the fan but look at the compressor he works; logically not working if the fan brings the temperature domatiou.antikatestise external capacitor again if the air conditioner does not work then the compressor is stuck.
What does E1 mean?
This is a reminder to clean the air filter. It happens every 720 hours of operation. Here are the steps to get it back up and running:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed the instructions above EXACTLY.
Turning off code e1 flashing
E1-Automatic filter clean
reminder.
Turn the air conditioner OFF and
unplug it. NOTE: The air conditioner must be unplugged for the automatic
filter clean timer to reset.
Clean the filter. See the Care
and Cleaning section in your use&care manual. After cleaning, replace the filter and plug
I have a Sharp Comfot
The unit will have a small amoount of water in it just make certain that it is tilted tot he ouside to help it drain. check the filter and clean it while your at it . let me know
