20 Most Recent
B&K AVR-307 Receiver Questions & Answers
How do i ground it
If your home has copper water pipes, then run a wire to the closest pipe and clamp it right to it.
Making a loud buzzing noise coming from the
Either some shielding baffles are loose and are vibrating or the transformer itself is generating too much sound . This happens when the power extracted thru it exceeds its capacity - there's a fault/short somewhere in the electronics. You will gonna have to open it and check for the fault.
States zone 1 off on startup. cannot get any
In the manual that I just uploaded on page 61 there is a big WARNING. You might have accidently adjusted the audio form zone 1 (main system audio) to turn off. use the manual I uploaded to walk you through the re-setup of zone 1. It's in 'main menu - system setup - advanced - Zone 1 Setup A'.
