20 Most Recent Black & Decker Vector MAXX SST Series, 2000 Watt, Red, Power Inverter Questions & Answers
With the vector 2000 watt converter do you need to
well unless you bought the 24 volt unit no one battery will run the unit, according to black and decker this unit is not being made, did you buy it new or at a yard sale?
one way to tell is look on bottom of unit, it will tell you if it is 24 or 12 volt model.
3/6/2011 8:24:50 PM • Black & Decker... • Answered on Mar 06, 2011
2answers
Fan doesn't run on my power inverter
I can't answer your question but I strongly suggest you urgently contact the manufacturer or dealer in order to clarify this most important point as a 3kw inverter isn't cheap and shouldn't need replacing very often.
8/31/2017 11:54:57 AM • Black & Decker... • Answered on Aug 31, 2017
Husky jump-start ac/dc adapter to charge Husky jump-start 400 amp
Sure, you can find it on amazon... here: Amazon com Husky jump start adapter . I hope I have helped. Cheers
12/1/2014 11:55:16 PM • Black & Decker... • Answered on Dec 01, 2014
The inverter turns on and fans run for
well the yellow light indicates a fault, the 5 volt USB is independent of the invert-er function, you kneed your unit serviced or possibly you have a low voltage cutout or high voltage protect ,check you manual for led fault indicator descriptions, battery voltages should be between 10.9 volts and 13.8 volts this can cause a fault if outside this range.best regards Falco
11/5/2013 7:02:01 AM • Black & Decker... • Answered on Nov 05, 2013
I bought a new Black and Decker 200 watt power
Most power inverters supply a modified sine wave output. This is different from the true sine wave you get at home. It's close enough for many applications, but not close enough for many transformers, which is what your laptop power supply is. So the problem is that your laptop's power supply does not work with a modified sine wave input. Some will, some won't. Very common problem.
8/23/2010 3:42:24 PM • Black & Decker... • Answered on Aug 23, 2010
I have a motormaster eliminator powe box 1200
Look on this site and see if yoou can find one with:
Correct dimensions
Correct voltage
Correct terminal connections
Don't worry if capacity is a few more amp hours. Some batteries have improved the capacity.
Use your measuring tape for size.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=393246&k=battery%20sealed
10/23/2009 2:29:41 AM • Black & Decker... • Answered on Oct 23, 2009
Vector 2000 Max inverter VEC054D turns on, LED
sounds like my inverter im going to change the mofset or.triod it has 3 prongs.
7/27/2009 4:20:21 AM • Black & Decker... • Answered on Jul 27, 2009
I have a Keb 12F5 that shows E.EF external fault. How to solve it please?
It appears to be something to do with this https://www.google.com/search?q=keb+12f5+that+shows+E.EF+external+fault 7.13.1.6 External fault With Pn.04 "Ext. fault input selection", one or more digital inputs can be programmed which can trigger the error "31: ERROR! External input" (E.EF). With Pn.03 "E.EF stopping mode" , the response of the inverter to the digital input is defined. With Pn.65/ bit 1 "2: Pn.04 = E.UP https://www.keb.su/doc/Instrukciya%20F5-A_E_H%20ver.4.0%20(ang.).pdf ..
2/27/2024 6:55:25 AM • Electronics -... • Answered on Feb 27, 2024
How do I connect my laptop to the TV?
Back in 2014 it wasn't so easy. Laptop with an HDMI port and a smart television with HDMI. ..
2/27/2024 6:47:57 AM • Electronics -... • Answered on Feb 27, 2024
2answers
I have an Emerson Quiet Kool Rooftop R/V air
I have a quiet cool roof top air conditioner and am looking for parts for it.
2/9/2024 5:25:36 AM • Electronics -... • Answered on Feb 09, 2024
Istar x 20000 USER MANUAL
Help in the link, but the one good site doesn't like my Ad Blocker! https://www.google.com/search?q=Istar+x+20000+USER+MANUAL ..
12/23/2023 11:37:12 PM • Electronics -... • Answered on Dec 23, 2023
Problem with oelmaier pac2 inverter
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjckMaPzKODAxUVj4kEHR5mBFMQFnoECBQQAQ&url=https%3A%2F%2Fforums.whirlpool.net.au%2Farchive%2F1447917&usg=AOvVaw1FGjdFQoufkwdXZJgXWdGz&opi=89978449
12/22/2023 5:44:02 PM • Electronics -... • Answered on Dec 22, 2023
Inverter problems
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj_qqPyyKODAxWLHjQIHZRbAW8QwqsBegQIDhAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DZ6e4aMeAfGQ&usg=AOvVaw1gC1aMLjnqHmsV7v7EZaQm&opi=89978449
12/22/2023 5:29:39 PM • Electronics -... • Answered on Dec 22, 2023
Black & Decker Vector MAXX SST Series, 2000 Watt, Red, Power Inverter Logo
1 questions posted
Top Black & Decker Electronics - Others Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Electronics - Others
Most Popular Question
vector 2000 watt converter need
  • Electronics - Others
