20 Most Recent Black & Decker Vector Cable Kit for 1200 Watt Inverter Questions & Answers
please send me the user manual for vf-5000(11Kw)?
Black & Decker... | Answered on Jan 31, 2018
some idea for inverter, collect inverter circuit Books from market.
Black & Decker... | Answered on May 28, 2012
Get it from here: http://freegyno.blogspot.com
I can't answer your question but I strongly suggest you urgently contact the manufacturer or dealer in order to clarify this most important point as a 3kw inverter isn't cheap and shouldn't need replacing very often.
Black & Decker... | Answered on Aug 31, 2017
Sure, you can find it on amazon... here: Amazon com Husky jump start adapter . I hope I have helped. Cheers
Black & Decker... | Answered on Dec 01, 2014
well the yellow light indicates a fault, the 5 volt USB is independent of the invert-er function, you kneed your unit serviced or possibly you have a low voltage cutout or high voltage protect ,check you manual for led fault indicator descriptions, battery voltages should be between 10.9 volts and 13.8 volts this can cause a fault if outside this range.
best regards Falco
Black & Decker... | Answered on Nov 05, 2013
Most power inverters supply a modified sine wave output. This is different from the true sine wave you get at home. It's close enough for many applications, but not close enough for many transformers, which is what your laptop power supply is. So the problem is that your laptop's power supply does not work with a modified sine wave input. Some will, some won't. Very common problem.
Black & Decker... | Answered on Aug 23, 2010
Look on this site and see if yoou can find one with:
Correct dimensions
Correct voltage
Correct terminal connections
Don't worry if capacity is a few more amp hours. Some batteries have improved the capacity.
Use your measuring tape for size.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=393246&k=battery%20sealed
Black & Decker... | Answered on Oct 23, 2009
sounds like my inverter im going to change the mofset or.triod it has 3 prongs.
Black & Decker... | Answered on Jul 27, 2009
no such product
Electronics -... | Answered 3 days ago
Please use laptop having serial port if not available then purchase a new original usb to serial of famous brand like Siemens, Lenze, MITSUBISHI, local brands may not works.
Electronics -... | Answered on Nov 25, 2020
There is not and those are not easy to get. China sites like alliexpress has them if you want to chance it.
Electronics -... | Answered on Nov 14, 2020
There are several ways to do this and several complications that may arise. That said, here is a brief outline of one method:
1. Locate the music folder on your PC.
2. Insert your flash drive into the USB port (allowing time for it to install or access drivers).
3. Click on Start, select My Computer. Locate your flash drive (most likely list as Removable Disk or the brand name of the flash drive). Double click on that icon.
4. Right click the folder or music files you found in step 1. Select "Send to" and choose "Removable Disk." The transfer process may take several minutes depending upon the number of files you are transferring. After the transfer is complete, click on the USB flash drive icon on the Windows task bar and select Stop or Eject. The PC will advise you when it is safe to remove the flash drive.
Here is a link to other ways to put music on a Flash Drive:
https://www.wikihow.com/Put-Music-on-a-Flash-Drive
https://www.youtube.com/watch?v=EQ4HSnlJiao
Electronics -... | Answered on Aug 03, 2020
  1. Remove the memory card from your camera.
  2. Insert the memory card into your laptop's PC card slot. ...
  3. Locate the destination folder where you want to store your pictures, in your laptop. ...
  4. Open the destination folder of your choice [source: Dummies.com]. ...
  5. Select Import pictures to my computer from the choices offered.
Electronics -... | Answered on Jun 17, 2020
Black & Decker Vector Cable Kit for 1200 Watt Inverter Logo
3 questions posted
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Electronics - Others
Most Popular Question
11kw pioneer vf 5000 inverter
  • Electronics - Others
