20 Most Recent Inverter 1000-2000w Peak Surge Power Questions & Answers
What are you trying to power with the inverter? Do you know how many watts your appliance need to run? Your 1000 watt inverter needs 83 amps from your battery to drive a 1000 Watt appliance. The minimum size wire you need to hook up the battery to the inverter is a size 6 as short as possible but no more than 25 ft.
Inverter... | Answered on Feb 01, 2012
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
Inverter... | Answered on Aug 02, 2011
check the fuse on the unit
Inverter... | Answered on Jun 17, 2011
This will cause big problems. It will not work and will likely cause both inverters to fail. Power inverters must create the 60Hz sign wave from a crystal controlled internal frequency driver. It's like a clock that keeps the timing at 60Hz. 2 independent units will have slightly different clocks both in time and frequency. This would cause the output waveform of one unit to be out of phase with the second. If they are out of phase, they will look like loads to each other and likely fail. It would be possible if the inverters had a way to link their clocks or use only one clock. This could be designed in however I have never seen this feature. You can hook up multiple inverters to the low voltage side (12VDC), just don't hookup their 120VAC output side. Hope this helps.
Inverter... | Answered on Jun 07, 2011
Soft start will slowly ramp up the current to the load preventing a surge of current from a cold start. It is similar to having an automobile and pushing the accelerator to the floor to accelerate from a stop using maximum engine horsepower. A soft start would be to accelerate gradually from a stop to the maximum engine horse power which would prolong the life of the motor.
Inverter... | Answered on May 23, 2011
the output power of your inverter is not constant... it needs constant input...
Inverter... | Answered on Apr 29, 2011
Request the manual from Kolin.
Inverter... | Answered on Nov 17, 2020
They dont offer that model any longer. You should contact them https://www.microtekdirect.com/contact-us/
Inverter... | Answered on Aug 08, 2020
J'ai un probl?me avec le vf5000 il fonctionne de 10 minutes ? 30 minutes et il s'arr?te et ?crit (p off) et il se rallume
Inverter... | Answered on Apr 18, 2020
You can see on the manual.
If you have plan to have a diesel generator set, please refer to www.dieselgeneratortech.com
Inverter... | Answered on Jan 09, 2020
internal problem
have it checked out by an accredited service repairer
Inverter... | Answered on Jan 03, 2020
Internal software error. You are to call Solar Edge for support.
Inverter... | Answered on Nov 26, 2019
Do you have a KEB Combivert? What model is it? Is your error .a prf or E.hybc or both? Hard to tell because you have posted 6 questions apparently.
Go to the KEB site, there are manuals and troubleshooting there, you will need to choose your correct model
https://www.keb.co.uk/drives/drive-controller-combivert/f5-application-drive
From another Fixya answer:
If you are talking about error code 59 then the error is E.HybC.
E.HybC means that the feedback card on the inverter has been changed.
You must confirm the change at parameter ec.0 or ec.10. The inverter reads the value from the feedback card so all you have to do it hit enter to confirm the value.
If you have not changed the feedback card but the error continues to come back then there is a problem with the feedback card or the control card.
Inverter... | Answered on Nov 09, 2019
Do you have a question? If so, please Edit the question or make Additional Information with the make and model of the device, what you are trying to do, and what the symptom is.
Maybe manualslib.com will have the PDF manual.
Inverter... | Answered on Sep 15, 2019
The reason why these things still draw power even with the power "off" is that the power switch doesn't actually disconnect the 12V input. What is happening is, the power switch shuts down all the inverter electronics, but everything is still connected and so can draw a little power. Usually they will draw only a slight amount of current, usually under 30 ma.
To stop all draw on your battery, unplug the inverter from the 12 volt power outlet. (Assuming it remains energized when the car is off.)
Inverter... | Answered on Jul 12, 2019
Check the loading resistors and capacitors feeding the transistors. My guess is a shorted cap on the drain.
Inverter... | Answered on Jun 16, 2019
Inverter 1000-2000w Peak Surge Power Logo
10 questions posted
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
Anon
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Inverter Electronics - Others
Most Popular Question
inverter keeps going
  • Electronics - Others
