20 Most Recent Briggs & Stratton Prosumer 20324 Gas Pressure Washer Questions & Answers
Pressure washer pump has become the most advantageous tool nowadays.
https://pressurewasherify.com/blog/whater-pump-repair-guide
Briggs &... | Answered on Jun 15, 2019
Should be on the carburator
Briggs &... | Answered on Jun 25, 2018
Up it should tell u on the switch if red start
Briggs &... | Answered on Jun 10, 2018
Go to motion industries or click here: Rings Hose Rubber Supply
or
Support Resources Briggs Stratton
Briggs &... | Answered on Feb 09, 2018
Try spray starting fluid into the air intake, that may get it going.
Briggs &... | Answered on Sep 26, 2017
Go to your dealer you may need to replace the o rings on the valve as they wer
Briggs &... | Answered on Sep 23, 2017
Turn your fuel switch on.
Briggs &... | Answered on Aug 30, 2016
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Sounds like water has gotten mixed in your oil.
Briggs &... | Answered on Nov 26, 2014
It sounds like someone put transmission fluid where the oil is supposed to go. Red fluid as much that I can remember is transmission fluid not oil. Probably just grabed the wrong bottle instead of oil. You need to drain it out good and fill with the right oil. Check and see if the oil in the motor is red.
Check the engine and high pressure pump oil levels. If you allowed it to get too low for long enough, one or the other may have been damaged or seized.
You may be able to get it running again with Marvel Mystery Oil, but some damage may have occurred that can not simply be undone with an oil or additive. It may burn / use much more oil from now on - so you will have to pay close attention to the oil levels.
Briggs &... | Answered on May 23, 2014
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Briggs &... | Answered on Jun 24, 2013
Sounds like the unloader is not working correctly. Try replacing it and see what happens.
Briggs &... | Answered on Sep 27, 2012
Briggs & Stratton Prosumer 20324 Gas Pressure Washer Logo
Popular Tags
70 questions posted
Top Briggs & Stratton Garden Experts
John Trevino
JOHN LAPIER
dannydoesita
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Briggs & Stratton Garden
Most Popular Question
won 39 t stay running
  • Garden
