20 Most Recent Kohler Riverbath Quadrangle Whirlpool w/ Integral Fill - K-1360-H2/Color=Bl Questions & Answers
I think the pump is going out on reset or hi limit
Kohler Riverbath... | Answered on Mar 13, 2009
The video given below may help you.
Kohler Water... | Answered on Aug 16, 2014
On all fixtures? Just one fixture?
Kohler Water... | Answered on Jul 15, 2014
1) Copy following link for step-by-step replacing gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/pdf//Which-is-best-gas-water-heater.pdf
2) Add a comment Feb 2013 for more help as needed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Kohler Water... | Answered on Feb 26, 2013
It is a gas appliance, it has to be serviced by a registered gas technician. They are too dangerous to try and fix yourself.
Water Heaters | Answered 3 days ago
here mate try this it worked for me.
Press left key
Scroll till page 15
Code will say 000 - should be 1000
Press right key once change first digit to 1
Press right key again
Will be on C1 in top right hand corner
Scroll through C pages till A1
Two A1 pages looking for one that says de..utch
Click right key once and change to d.. English
Water Heaters | Answered on Jan 04, 2021
The red LED may be indicating that the temperature control has failed.
Water Heaters | Answered on Jan 02, 2021
Contact Titan to request the information.
Water Heaters | Answered on Dec 16, 2020
Jennifer, the instructions posted by Rheems on the heater are wrong. You must first rotate the dial clockwise, use force (in our our case) to get the pilot to its position. The folks at Rheems are nuts not to check their instructions before printing them and plastering them on their hot water tanks. Disgraceful, period.
Water Heaters | Answered on Nov 28, 2020
I have taken pictures and produced a wiring diagram for this model
Water Heaters | Answered on Nov 09, 2020
when cycling to start check ignitor see if it glows if no check voltage to it if yes replace ignitor
Water Heaters | Answered on Nov 01, 2020
look for display or control board if no buttons then cant adjust
Water Heaters | Answered on Oct 22, 2020
Automatic battery chargers have complex circuitry that is difficult to test especially when designed and built in a compact package and repairs are best entrusted to someone geared to such work which is outside the scope of general electronics.
On the plus side, as long as the intelligent circuitry is protected against mains borne surges and spikes the automatic charger is somewhat self-protecting against over stress and will tend not to even attempt to charge a defective battery, a sulphated or overly discharged battery.
I suggest you first check the battery or batteries to ensure they are healthy and have some charge so the charger can "see" them before condemning the charger and also check the connections to the battery that must be virtually perfect...
Water Heaters | Answered on Oct 05, 2020
Depends on the problem you have .if you are unable to fix it the option of calling a plumber is there .
Water Heaters | Answered on Sep 07, 2020
When the noise occurs when there is no hot water being used, it's likely there is a vacuum that's siphoning water away from the unit and causing loud noise and vibration. ... Another common problem that can create noise in tankless water heaters is a dirty flow sensor which controls how much gas is sent to the unit.
https://www.youtube.com/watch?v=Fsb8Wx9PRvY
Water Heaters | Answered on Jun 24, 2020
NO HOT WATER
  1. If the tester indicates there is power to the terminals and the water in the geyser is cold, then the element is faulty. ( ...
  2. If the tester indicates there is no power to the terminals and the water is cold, then the thermostat is faulty.
https://www.youtube.com/watch?v=qCXmyhEY_k4
Water Heaters | Answered on May 06, 2020
Kohler Riverbath Quadrangle Whirlpool w/ Integral Fill - K-1360-H2/Color=Bl Logo
1 questions posted
Top Kohler Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Kohler Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Kohler Water Heaters
Most Popular Question
heater doesnt work correctly
  • Water Heaters
