Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live. For a price, expert works with you while you work on water heater or any do-it-yourself project. Fixya is always less expensive than a service call.
1) Never, ever install tankless water heater, unless your wallet is 2" thick and you enjoy nuisance problems and recommended continual maintenance. 2) Add in-line air vent. http://waterheatertimer.org/images/Air-vent-added-to-return-22.jpg 3) Look for check valve along the line. Look for mixing valve, pressure regulating valve, etc. 4) If you have recirculation system, remove cross-over check valve and see if problem is located there. 5) Contact Rheem. 800-432-8373 They will want model number, serial number, and name of installer. And might recommend contacting installer or plumber. 6) Increase water flow. Check water flow requirement of tankless (.5 gallons per minute activation) with actual flow at faucet. 7) Clean water filter at tankless unit. http://waterheatertimer.org/pdf/Tankless-maintenance.pdf 8) Crossover at single-handled faucet. http://waterheatertimer.org/Crossover.html 9) Fix all leaking faucets indoor and outdoor so no air is being sucked in. 10) Bad TP valve on water heater sucking in air each time water pressure pulls on the valve?
As general rule, tankless repairs are done by someone trained and certified by manufacturer. This is because tankless are complicated and problems range from water quality, water pressure, air quality, venting, burner maintenance, sensors for each of the parameters listed above, and can also be a combination of factors.
the error code is either a bad remote, or bad cable or a bad PCB,
you can try and unplug the heater from the 110 outlet and then unplug the remote from the PCB ( leave it un-done ) and then plug the unit back into the wall outlet. this should give you hoy water until the part is fixed.
Rheem is aware of this problem and if you call them, they will ship you out the replacement parts to fix your unit at no charge to you, plus they will send to you the installation instructions which are very easy to follow.
Rheems contact information is: 1 800-720-2076 -- www.rheem.com
also for more error code information go to : http://www.rheem.com/products/tankless_water_heater/customer_support/
The three most common reasons for this happening to you are 1) a defective gas valve, 2) a rusty thermopile, and/or 3) the automatic shut-off not working as it should.
So, the most common reason for many people having this problem stems from having a gas valve that is not working as it should. When your gas control valve is faulty, it will mean that your burner is not going to be igniting as it should-or at all.
Something that worked for me one time was to turn the Temp all the way down then all the way to Max a couple of times..gradually.
Why it worked I don't know. Got a couple more years out of it though. Good luck!
Best to you.
Rheem furnace error code 68 is a mechanical relay system which signals the blower motor to stop because it has not received a signal from the thermocouple.
Jul 20, 2022
ManualsLibhttps://www.manualslib.com > Rheem-96v-Series
Motor Power And Communications Issues (Fault Code "68"); Line Voltage And Low Voltage Connections To The Communicating Motor - Illustrations - Rheem 96V Series ...
The burner cover plate for your Rheem RRNL-B030JK08E unit can be obtained from an authorized Rheem dealer or distributor. You can visit the Rheem website to locate a dealer or distributor in your area. Alternatively, you can contact Rheem customer service for assistance in obtaining the burner cover plate. Be sure to have the model and serial number of your unit available when contacting Rheem customer service.
