20 Most Recent Sharp AQUOS 90 inch LE745 Series 3D LED Black Flat Panel HDTV Questions & Answers
90 sharp does not turn on no pic or sound. Blinking white 2 long 2 short
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
1/6/2014 11:31:23 AM • Sharp AQUOS 90... • Answered on Jan 06, 2014
Scanned Channels not saving on my Sharp AQUOS 32 LE185M LED TV.
https://elektrotanya.com/cgi-bin/download2.cgi?dk=wgzgtxz9xfakb6w5s2gbjalr7l6hmh579r0th7lfiongeyjc&fid=105643&file=sharp_aquos_lc32_40_46_52le700un.pdf Should be the faulty memory IC. Download its service manual by the above link, and refer it. If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
10/16/2021 6:51:04 AM • Sharp Aquos... • Answered on Oct 16, 2021
Sharp Aquos LC-52D62U Liquid Crystal Display; Power LED blinks at a constant rate. TV does not come on.
This model was known for bad capacitors in the power board, have you tested them and or power supply voltages?
8/20/2021 12:01:51 AM • Sharp Aquos... • Answered on Aug 20, 2021
2answers
How can I fix my Sharp Aquos TV screen that turn red
One way to deal with this issue is to power cycle your Sharp TV. This way you will be able to find out if the light blinking is due to improper bootup and hopefully resolve it. https://downloadnox.onl/ https://vidmate.vet/ https://vlc.onl/
8/17/2021 11:38:19 AM • Sharp Aquos... • Answered on Aug 17, 2021
Where or is the volume button on my Sharp Aquos tv? I ordered a remote but it won't be here till Sat. Thank you for accepting me on here :
What is the model number of that TV. without it, how can one respond? If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/
7/17/2021 11:59:25 AM • Sharp Aquos... • Answered on Jul 17, 2021
My sharp aquos LC-60LE644U works for 10-15 minutes off antenna
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. . Pull up older posts. http://electronicshelponline.blogspot.com/ . https://elektrotricks.blogspot.com/ http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site by type in the brand name of your TV, at its search box at the right column. View the sites by desktop computer or by Webview by mobile. Mobile view has no search box.
7/11/2021 1:34:53 PM • Sharp Aquos... • Answered on Jul 11, 2021
2answers
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
12/30/2019 1:23:58 AM • Sharp Aquos... • Answered on Dec 30, 2019
What is factory reset code for LC46LE700E
11/17/2019 3:07:14 AM • Sharp Aquos... • Answered on Nov 17, 2019
I have no sound on my sharp aquos 60" TV.
We have the same TV. In settings for sound you need to select the port directing where you want sound to play. It may be that it is currently setup to play to a sound bar.
10/6/2019 2:54:36 PM • Sharp Aquos... • Answered on Oct 06, 2019
How to change the country setting on sharp aquos?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1/6/2019 7:55:28 PM • Sharp Aquos... • Answered on Jan 06, 2019
Sharp AQUOS 90 inch LE745 Series 3D LED Black Flat Panel HDTV Logo
2 questions posted
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
90 sharp not turn no pic or sound
  • Televison & Video
