20 Most Recent
Sharp R-1406 Microwave Oven Questions & Answers
Sharp microwave model R-1406 control panel has no
We
regularly repair such control
units for
customers nationwide by mail for $39.95 postpaid with a one-year guarantee.Details of our service are at
our Web site, along with a video showing how to remove a typical
over the range control panel assembly in under 5 minutes.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
We have a r-1406 power to outlet nothing at
No reset, and if it's totally dead, it may be the fuse, the magnetron's temperature fuse, or the cavity thermal cutout.
We have the service manual and have uploaded it to our site
here to help you.
The fuse should be accessible just behind the grill.
At
our Web site, we have a video
available showing how to remove a typical
over the range grille and/or control panel assembly in under 5 minutes.Accessing the oven cavity thermal cutout will require you to remove the oven from the wall, then remove the outer cover.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
The installation instructions are included in your owner's manual.
If for some reason you don't have yours, you can download it from our site here.
We're
happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
What is the wattage for a sharp microwave model R-220AW? 1997
? de aproximadamente 600 watts. No entanto, ? importante notar que as informa??es espec?ficas sobre a pot?ncia podem variar ligeiramente dependendo do modelo exato e das condi??es de uso ao longo do tempo. Se voc? precisar de informa??es precisas sobre o modelo espec?fico que possui, recomendo consultar o manual do usu?rio ou entrar em contato diretamente com o fabricante.
Why Does My Sharp Microwave Turntable Get Hot?
I hope you didn't run the microwave with nothing in the cavity, if you did, it will damage the magnetron.
The turntable dishes do get hot depending on the quality of the glass used to make it. Heat is caused by impurities in the glass.
If you run it with no food in the oven, the glass will try to absorb the energy with atastrophic results usually.
My sharp Double Grill & Oven R795 will not heat up to temperature, when used as an oven . Microwave side is ok, can any body help
You might attempt the following troubleshooting steps:
Ensure sure the temperature settings are accurate and that you have given the oven enough time to warm before putting food inside. Check the oven temperature settings. To learn how to adjust the temperature properly, consult the user handbook.
Examine the heating components since they can be broken if the oven is not heating at all. When the oven is switched on, see if the heating components are blazing red. The heating components might need to be replaced if they are not.
Examine the oven thermostat: If the temperature fluctuates or fails to reach the desired level, the thermostat may be malfunctioning. Replace a broken thermostat if necessary.
Verify that there are no blockages inside the oven that could be preventing the heat from circulating. Debris, foil, or bakeware that is too big or that covers a significant amount of the oven rack might all fall under this category.
Sharp Drawer Microwave SMD2489ES. All indications of *****.
It is a motorized drawer and I doubt it likes being opened manually. It would need to be repaired professionally due to the inherent dangers of microwave energy. The drawer motor would be operated by a relay.
Did you read any reviews before you purchased it?
IanFromOhio
a year ago
Thumbs Down
- Looks great but features are bad.
Drawer microwaves and this model in particular look great. We did a big reno in December and this is now in the island. Looks good and functions as a basic microwave. Everything else is just south of mediocre. I'd suggest you get a drawer microwave from another company. Bad Stuff: - door opens/closes very slowly (~4 seconds)... doing a 30 second reheat now takes 4+4+30+4+4 = 50% longer just standing around. Likely similar with other drawers, but an unexpected negative. - doesn't let you tell it to start until fully closed - its default sounds and reminders are ridiculously annoying - beep-beep-beep on finish, and 10 seconds after that, and 10 seconds after that, and.... on and on - it forgets all settings during a power outage, turning back on the annoying sounds - and forgets your network connection - but good news, you won't want to use that feature - controls are not intuitive - classic 40 buttons where you use 5 The WiFi & App - hilariously bad. Design in your head the things you would want in a microwave app. Sharp engineers designed the opposite. Can you set the alarm settings in the app? No. Do you get a notification each time the microwave finishes cooking? Yes. I guarantee you will delete the app within 48 hours. Hand Wave to open. Neat right? No. Take how long it takes for this thing to open/close and add another 4-8 seconds of waving your hands (which are full food, else you'd just press the button) to then wait for the drawer to open. Push to close works well, but it reacts in a weird way, so some concern I'm breaking it. I stopped doing wave to open after the first week and stopped trying to demonstrate it to friends after one month (cause it will make you look silly). Height - just tall enough - fits a Venti coffee Cooks at 950 watts - basically the same power as a college-dorm microwave Cost. my god, how much did I spend on this. The good: Looks good Flush install if you have a good installer; mine is shown in a 30" wide lower microwave cabinet by Medallion Reheat sensor cook works well push to close works. It was suggested that I buy a Sharp because they have the patent on the drawer microwave and everyone else is just a re-labelled Sharp. I would suggest you give the others a look. They may be using the same hardware, but hopefully they have a more customer-focused interface and better software engineers working for them.
Reviewed on bestbuy.com
How to set the clock on my sharp carousel
Touch STOP/CLEAR pad.
Touch TIMER/CLOCK pad.
Enter the correct time of day by touching the numbers above in sequence.
(for example: for 12:30, touch 1 2 3 0)
Touch TIMER/CLOCK pad again.
On my Sharp CD-C492, the door for CD doesn't open and it say E-03, how can I fix it ?
The E-03 error on a Sharp CD-C492 CD player typically indicates a problem with the door or the mechanism that opens and closes the door. Here are a few steps you can try to fix the issue:
- Check for foreign objects: Make sure that there are no foreign objects blocking the door or preventing it from opening.
- Check the door hinges: Inspect the hinges on the door to ensure that they are not damaged or stuck. If the hinges are damaged or stuck, try gently wiggling them to see if this helps free them up.
- Check the door switch: Locate the door switch, which is usually located near the hinges on the door. Check to make sure that the switch is functioning properly and that it is not stuck or damaged.
- Check the door motor: If the door switch and hinges are functioning properly, the problem may be with the door motor. Check to make sure that the motor is functioning properly and that it is not damaged.
If you are unable to fix the issue using the steps above, or if the error persists, it is recommended to have a qualified technician take a look at the CD player to diagnose and repair the problem
