20 Most Recent
Sharp R-1514 Microwave Oven Questions & Answers
Turn off sound
you must test the speaker with VOM continuity 2) reset the microwaves disconnect the power cord by 40 seconds and try again. 3). Defective/damaged touchpad.God bless you
Display panel r-1514
Possible that the control pad or the main board or the processor is faulty. You can remove the top cover after disconnecting and remove the front panel, check for insects within that have nested , if so clean the board and reset the panel connection. If not you can call for help to Sharp support at your place.Check website
: Sharp
I lost the underside light
You didn't mention your brand or model, but here is a generic answer.
You can find links to helpful exploded view diagrams and part ordering help
here.
I recommend that you bookmark that link to your favorites.
Be sure to unplug the oven before you remove or insert the bulbs, or
circuit board damage can occur. We fix that, too.
We're
happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
Microwave just stopped working.. The
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
YOUR
SAFETY IS PARRAMOUNT
This is a job for a professional but if
you are safety clued up, here's instruction.
Make sure the
!!!!capacitor is discharged!!!!! before attempting any
sort of repair.
Check the door interlock switches first then the
high voltage diode with either an AVO model 8 or moving coil meter on
high resistance range for short circuit, (DVM's won't show the
fault!), the capacitor can fail and go short circuit, the feed fuse
on the primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
How do I remove this microwave from my under the
The installation instructions show you how to install it, so you simply work backwards.
I have uploaded them to our site
here.
NOTE: I would be very interested in buying your control panel assembly from that oven.At
our Web site, we have a video available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly about this:
William E. Miller [email protected]We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
THE LIGHTED DISPLAY IS NOT READABLE THE DIGITAL
We regularly
repair these control units for customers nationwide by mail for $39.95
postpaid in about a week or so with a one-year guarantee.
At
