20 Most Recent Sharp R-308H Microwave Oven Questions & Answers
manual
Emerson Microwave Oven and Grill MWG9111SL
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kgjlkglj
9/30/2010 10:57:46 PM • Sharp R-308H... • Answered on Sep 30, 2010
3 digits on touch screen on my Sharp Microwave
hi my name is mark, you will have to replace the board. manufacters call things like that non-servicable. sorry. thanks for your question.
3/15/2009 5:42:38 PM • Sharp R-308H... • Answered on Mar 15, 2009
3answers
Sharp R-305KS door release problem
yes this can be broken definately and you can get the required part at.
http://www.applianceaid.com/nuker.html
2/23/2009 12:21:28 AM • Sharp R-308H... • Answered on Feb 23, 2009
Yes it is possible the door open lever got broken in shipping.
If your model has anti-tamper screws, you can remove them using using a T20H Torx type or GTXH20-100 screwdriver. If the correct tool is not available, there are several ways to remove the screws:
- Use a hammer and a small punch or similar tool to knock out the middle post of the screw, then use a standard T20 Torx bit to remove the screws. (Use safety glasses).
- Insert a small flat-bladed screwdriver (such as a jeweler’s type) into the slot between the post and the edge, tap the screwdriver firmly with a hammer to loosen the screw, grip the screwdriver with pliers, and remove the screw.
- Use a hacksaw or Dremel tool to cut a slot in the head of the screw, then use a flat-bladed screwdriver to remove the screws. (Use safety glasses).
Once the cover's off, you can see the door opening parts. It's probably the lever.
The best place to order Sharp parts is Tritronics.
2/23/2009 12:04:37 AM • Sharp R-308H... • Answered on Feb 23, 2009
Microwave doesn't cook
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. If you hear nothing, you might have a defective transistor on the main printed circuit board. This is not easily fixed; contact a service technician. You can try the "find a microwave repair..." link from the product page. Good luck!
6/20/2006 1:22:37 PM • Sharp R-308H... • Answered on Jun 20, 2006
Hi our Sahrp Carousel microwave LCD panle display is not working
You have to replace the control board. Sharp has had problems with the display boards for awhile. There is no bulb or fuse you can change.
1/15/2023 8:13:20 PM • Sharp Microwave... • Answered on Jan 15, 2023
On my Sharp CD-C492, the door for CD doesn't open and it say E-03, how can I fix it ?
The E-03 error on a Sharp CD-C492 CD player typically indicates a problem with the door or the mechanism that opens and closes the door. Here are a few steps you can try to fix the issue:
  1. Check for foreign objects: Make sure that there are no foreign objects blocking the door or preventing it from opening.
  2. Check the door hinges: Inspect the hinges on the door to ensure that they are not damaged or stuck. If the hinges are damaged or stuck, try gently wiggling them to see if this helps free them up.
  3. Check the door switch: Locate the door switch, which is usually located near the hinges on the door. Check to make sure that the switch is functioning properly and that it is not stuck or damaged.
  4. Check the door motor: If the door switch and hinges are functioning properly, the problem may be with the door motor. Check to make sure that the motor is functioning properly and that it is not damaged.
If you are unable to fix the issue using the steps above, or if the error persists, it is recommended to have a qualified technician take a look at the CD player to diagnose and repair the problem
1/3/2023 10:38:28 PM • Sharp Microwave... • Answered on Jan 03, 2023
My Sharp Carousel Micro/Convection Oven R-1870, Begans to Blow out Black Smoke when the Microwave option is used. The convection oven works perfectly.
DO NOT use this oven for any of the functions! You will need to get a specialist to look at this! Smoke suggests a motor or the wiring to it is burning out. Is this a free standing unit or a built in setup? Free standing unit or often not too expensive to replace and there are lots of Companies who make good upgrade models. Get quotes for the repairs from 3 or 4 different places and compare that to the cost of a replacement.
11/24/2022 6:29:20 PM • Sharp Microwave... • Answered on Nov 24, 2022
2answers
Sharpe Grill2 Convection Microwave manual
Hi, please call sharp over the phone and ask them to email the manual to you so that you can receive the document without paying any shipping fees. If you need to print it out and it has many pages, you can do so at your local office depot or kinkos. Than you.
11/19/2022 5:07:53 AM • Sharp Microwave... • Answered on Nov 19, 2022
Sharp microwave drawer wont open
My drawer has been sticking for years and always required a little force to get it to open. Just fixed it by putting a little silicone grease on the drawer hooks that are exposed when the drawer is open
10/23/2022 1:36:57 PM • Sharp Microwave... • Answered on Oct 23, 2022
Microwave owen SHARP Model R9H20 Digital
R-9H20 (W) sharp microwave oven- the turn plate does not work kindly let me know what needs to be done. i need help. Kindly e-mail me .
[email protected]
Zaffar Iqbal
10/10/2022 4:07:34 AM • Sharp Microwave... • Answered on Oct 10, 2022
Sharp carousel 8888 is flashing and I cannot remove it
In case of unavailability of touch panel regarding any model of your microwave you can simply asked your repairman to install micro touch buttons (easily available and can be fixed) on the base of touch panel than repest the panel over it. It would work like the same.
10/7/2022 5:18:12 AM • Sharp Microwave... • Answered on Oct 07, 2022
2answers
Please tell me how to use the sharp microwave oven r-9h20 model for baking cakes please tell me
I searched using https://www.google.com but did not locate an instruction manual for that model Sharp microwave oven. Recipe at the link below suggests adding extra sugar before baking. https://www.allrecipes.com/recipe/140772/easy-microwave-chocolate-cake/?_ga=2.211667349.160497590.1579435247-959462057.1579435247
10/7/2022 4:51:26 AM • Sharp Microwave... • Answered on Oct 07, 2022
Sharp half pint microwave door latch broken - how can I fix it?
Okay. I got the Half Pint Microwave door off, opened it up, found the spring, used a Dremel to make a new point of attachment for the spring since the spring flang on the dooor was indeed broken. The door closes now and microwave turns on - but it doesn't stay on, unless I apply pressure on the top right corner of the door. So the latch is just slightly out of alignment. Will tinker with it some more. Maybe it's just a matter bumping up the lower part of the door a bit. Has anyone encountered this problem?
8/31/2022 6:06:09 PM • Sharp Microwave... • Answered on Aug 31, 2022
Sharp R-308H Microwave Oven Logo
9 questions posted
Top Sharp Microwave Ovens Experts
Jaime Hernandez
nu267
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Microwave Ovens
Most Popular Question
sharp r 305ks door release problem
  • Microwave Ovens
