20 Most Recent HP 4440s Probook Questions & Answers
Is TPM Option available in HP 4440s?
it is a one w3y trip,TPM and if you mess up boom bricked for ever. are you with CIA, only CIA,DOD.NSA ,DOJ use this the BIOS pages if looked snow this is there or not hp.com read your manual, 4440s the OS must support it too, none told at all. I say avoid it like the Plague, unless working for the MOB?(grin)
1/14/2022 9:30:41 PM • HP 4440s Probook • Answered on Jan 14, 2022
2answers
I am unable to get brightness option in laptop, i tried so many things.plz help
Common complaint with this unit. First you should try installing the HP Software Framework and HP Hotkey Support. After installing this two pieces of software reboot your computer and see if the issue is resolved. If this doesn't resolve the issue you should install and run HP Support Assistant. This will scan your computer and attempt to locate and install any other missing software for your notebook.
4/29/2015 10:44:36 AM • HP 4440s Probook • Answered on Apr 29, 2015
The moniter is blank, white, with no cursor, when I start up the computer.
do you have a picture on bios loading..if you have try without battery.remove driver in safe mode and if that dont help you try with new hdd .. or you have dead gpu
3/25/2015 9:38:58 PM • HP 4440s Probook • Answered on Mar 25, 2015
2answers
My laptop dnt have Bluetooth option I have
Hello, in order to have bluetooth on your laptop, you have to get a bluetooth adapter if you laptop does not have a inbuilt bluetooth device. (Some bluetooth devices: http://www.amazon.com/s/ref=nb_sb_ss_i_0_11/184-7354543-5016551?url=search-alias%3Delectronics&field-keywords=bluetooth%20adapter&sprefix=bluetooth+a%2Celectronics%2C409&rh=i%3Aelectronics%2Ck%3Abluetooth%20adapter)
3/20/2015 12:03:36 PM • HP 4440s Probook • Answered on Mar 20, 2015
I cannot increase scree brightness of my HP PROBOOK 4440s Also tried by getting in to power option in control pannel and moved the slider... even then there is no change in brightness
Go to the system tray in the lower right bottom of your screen and click on the "plug and battery" icon. Left click on it and you will see a link to "Adjust Brightness" towards the bottom of the menu. AND ALSO Go to control panel. choose display. Click on "adjust brightness". You find " Select a power plan". You can increase brightness at the bottom of the screen. it's work for me.
2/23/2015 11:03:38 AM • HP 4440s Probook • Answered on Feb 23, 2015
My hp probook 4440s dc jack led blink when plug the adeptor not power on I have already hard reset the notebook
I think you are having problem with your charging port, take it to an expert
8/19/2014 8:35:29 AM • HP 4440s Probook • Answered on Aug 19, 2014
Speakers not working properly
change the player or use VLC Player
5/23/2014 1:40:55 PM • HP 4440s Probook • Answered on May 23, 2014
Shuting down very slow
To check for performance issues
  1. Open Performance Information and Tools by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, type Performance Information and Tools, and then, in the list of results, click Performance Information and Tools.
  2. In the left pane, click Advanced tools.
  3. In Advanced Tools, under Performance issues, click any issues that are listed.
  4. Read the information in the dialog box that appears to learn which programs or drivers are causing problems.
If a program or driver prevents your computer from turning off quickly You can try the following tasks to fix the problem:
  • Close the program before shutting down. It's possible that the problem occurs only if the program is running. Try closing the program before shutting down Windows, and then see if your computer turns off properly.
  • Check with the manufacturer of the program or driver for an update. A newer version of the program might include a resolution to the problem.
If these options don't solve the problem, then the program or driver might be incompatible with Windows. If you installed the program or device yourself and you no longer use it, consider removing the device, or uninstalling the program or driver.
4/15/2014 9:00:16 AM • HP 4440s Probook • Answered on Apr 15, 2014
Function keys not working on hp probook 4440
Identifying the hot keys A hot key is a combination of the fn key and either the esc key or one of the function keys. To use a hot key: Briefly press the fn key, and then briefly press the second key of the hot key combination. Hot key combination Description fn+esc Displays information about system hardware components and the system BIOS version number. fn+f1 Initiates Sleep, which saves your information in system memory. The display and other system components turn off and power is conserved. To exit Sleep, briefly press the power button. CAUTION: To reduce the risk of information loss, save your work before initiating Sleep. fn+f2 Decreases the screen brightness level. fn+f3 Increases the screen brightness level. fn+f4 Switches the screen image among display devices connected to the system. For example, if a monitor is connected to the computer, fn+f4 alternates the screen image from computer display to monitor display to simultaneous display on both the computer and the monitor. Most external monitors receive video information from the computer using the external VGA video standard. The fn+f4 hot key can also alternate images among other devices that are receiving video information from the computer. fn+f5 Initiates the QuickLock security feature. QuickLock protects your information by displaying the operating system Log On window. While the Log On window is displayed, the computer cannot be accessed until a Windows user password or a Windows administrator password is entered. NOTE: Before you can use QuickLock, you must set a Windows user password or a Windows administrator password. For instructions, see Help and Support. To access Help and support, from the Start screen, type help, and then select Help and Support. fn+f6 Displays charge information for all installed batteries. The display indicates which batteries are charging and reports the amount of charge remaining in each battery. fn+f7 Mutes or restores speaker sound. fn+f8 Decreases speaker volume. fn+f9 Increases speaker volume. fn+f10 Plays the previous track of an audio CD or the previous section of a DVD or a BD. 32 Chapter 4 Pointing devices and keyboardHot key combination Description fn+f11 Plays, pauses, or resumes an audio CD, a DVD, or a BD. fn+f12 Plays the next track of an audio CD or the next section of a DVD or a BD. http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c03555111-1.pdf
3/16/2014 5:26:03 AM • HP 4440s Probook • Answered on Mar 16, 2014
Wifi and bluetooth button
Contact the HP support webpage and download the HP Hotkey Support Driver.
2/19/2014 10:20:26 AM • HP 4440s Probook • Answered on Feb 19, 2014
Speed very slow
1. Add more memory (RAM), 2. Change the hard drive with SSD drive (it will significantly improve your laptop speed).
12/25/2013 10:01:21 PM • HP 4440s Probook • Answered on Dec 25, 2013
0answers
2answers
How can i clean up my pc for free
Download a Ccleaner and run its all tools. After performing that your PC will be cleaned up.
10/24/2013 8:57:31 AM • HP 4440s Probook • Answered on Oct 24, 2013
Turn fn key
There is a "Fn" key next to the "Ctrl" key on the left of the keyboard.Keep it pressed when pushing on one of the funktions on the top of the keyboard (next, play, stop, ...).If this answers your question, please mark this as "Answered".
10/8/2013 11:43:21 AM • HP 4440s Probook • Answered on Oct 08, 2013
Last year we've purchase a dozen of hp 4440s
No is common that case, because core i3 normally is working well, may be the PLOBLEM its possible the office 2010, review the updates and search somes fixes for bugs of this application of microsoft
9/27/2013 4:31:50 AM • HP 4440s Probook • Answered on Sep 27, 2013
Windows boot manager keeps appearing before
does your pc then start up normally.
9/21/2013 12:05:38 AM • HP 4440s Probook • Answered on Sep 21, 2013
I dnt have the Bluetooth option in my laptop what
Got to HP.com and enter your model number. Your laptop specs are listed there. If you don't have it, no problem! Some laptops do not have Bluetooth. No worries you can buy a small USB Bluetooth stick, Google "USB Bluetooth"
9/12/2013 5:09:11 AM • HP 4440s Probook • Answered on Sep 12, 2013
HP 4440s Probook Logo
56 questions posted
Top HP Computers & Internet Experts
Ekse
Mehandi Husain ...
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ProBook HP
  • ProBook HP
Most Popular Question
tpm option available in hp 4440s
  • Computers & Internet
