20 Most Recent HP 15.6" Compaq Presario CQ58-A10NR Laptop PC with AMD E1-1200 Questions & Answers
How to format the compaq laptop
the boot drive? or what. not told what.
5/1/2022 4:57:04 PM • HP 15.6" Compaq... • Answered on May 01, 2022
How can i adjust brightness for hp compaq cq58 laptop
ccfl screen all this old are dead or bad. or turn yellow. all do. all did. all you can do is turn up the brightness or replace the tubes CCFL are back lamp tubes. for the SCREEN CQ58-nnn what, what it the full service tag Partnumber. ill toss the 50 sided coin and land on cq58-100 the 100 model, is LED and not CCFL lamps so what OS is running? Windows 7? i yes, see the users guide on bightness. read page 26 the magic F3 key. if the key fails, that means, the drivers loaded on this pc are wrong. http://h10032.www1.hp.com/ctg/Manual/c03308662 correct drivers are alway here at REAL HP (we are not hp) im picking w7-64bit now, if not 64bit go back and change that first. https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq58-100-notebook-pc-series/5259203
9/26/2017 11:47:17 AM • HP 15.6" Compaq... • Answered on Sep 26, 2017
Doesnt swich on
this pc sold from 2012 to 2014 and is NOT NEW, at all. sold with W7 and W8, only, new all have w10, And HP does support still. (my guess till 2024) no operating system stated by you btw. ok,, I do the dead only. wow a real service tag model stated. super good that. can I assume the screen never ever show even 1 line of text? ill assume that is true, and respond, i cant see your screens. so.. CQ58-A10NR how to fix a LT , that is I presume DEAD .? black screen simple steps on all DEAD LT
  1. take out the battery does it work now y/n???????
  2. does the ESC key BIOS key work? power on hammer ESC or F9 or F11, if those all work the BIOS IS GOOD and power is ok
  3. if BIOS is dead the power pack is bad. (or worse, worse in not limited at all with over 3billion transistors inside.
  4. see this?
http://pcdied.com/black-screen.html The power pack is bad if the PC will not run with AC only. battery out. the pack can be bad. AC line pack its like $15 , vastly less than the typ. $300 shop labor charge alone.. your support page is below! https://support.hp.com/us-en/product/Compaq-Presario-CQ58-a00-Notebook-PC-series/5259206/model/5273664
7/28/2017 3:20:17 PM • HP 15.6" Compaq... • Answered on Jul 28, 2017
Cant adjust the screen brightness of compaq CQ58
Some monitors, have an options in the driver section, for others, NVIDIA drivers, have options for contrast of brighness. others laptops have a key convinations, like FN + another key to bright or contrast the color. look your keyboard for those keys, sometimes has a little sun design
1/26/2017 6:51:57 PM • HP 15.6" Compaq... • Answered on Jan 26, 2017
How do i download a disc to restore my compaq presario cq58 to factory setting?
Call Compaq at 800-888-0220 they will mail you one for a small nominal fee.
8/11/2014 8:52:04 AM • HP 15.6" Compaq... • Answered on Aug 11, 2014
How to change setting in bios to boot from cd drive"?"
you usually dont have to change the boot order to boot from a cd. the bios should check the cd rom before booting from the hdd. However, if that isnt the case, you can always change the boot order. go to the bios settings while u turn your laptop on. (It should be "esc" for HP. a message will be displayed at the bottom of the screen indicating the key. if not, try esc, f10, f11, f12. either one of them should work). go to the boot order settings (May have a different name- boot settings/ boot priority settings/ advance boot options etc.).
7/17/2014 12:11:31 PM • HP 15.6" Compaq... • Answered on Jul 17, 2014
My keypad is not working, when i type in nothing
check the bios setting or check it by some external keypad
5/23/2014 2:02:42 PM • HP 15.6" Compaq... • Answered on May 23, 2014
My laptop compaq CQ58 does not start up so it gives me this message selected boot image did not Authenticate. Press <Enter> to continue. If l press continue it switches off, Pliz help wat should
Remove the hard drive and read it as an external drive using another computer. Also, test it and fix it using a Norton Utility (it can be downloaded from CNET; go to google and search it using keywords: "Norton utility download cnet")
3/12/2014 9:25:19 PM • HP 15.6" Compaq... • Answered on Mar 12, 2014
Boot image did not authenticate
My laptop compaq CQ58 does not start up so it gives me this message selected boot image did not Authenticate. Press <Enter> to continue. If l press continue it switches off, Pliz help wat should l do
3/12/2014 8:56:15 AM • HP 15.6" Compaq... • Answered on Mar 12, 2014
Internet explolar 8
You can do this: [Start], Control Panel, Network and Sharing Center, Change Adapter Settings, click the WiFi, click Change Settings of this Connection. In the Networking tab, scroll down. If you see unchecked Internal Protocol Version 4 (TCP/IPv4) box, then check it. If you don't see the TCP/IPv4 in the list, then you need to click the Install button and follow the instruction.
3/5/2014 2:15:44 PM • HP 15.6" Compaq... • Answered on Mar 05, 2014
About keybord
check the keyboard settings are correct. eg a US keyboard setting will give the @ symbol where the " symbol is. look in control panel/ keyboard/language settings for your options
12/23/2013 6:02:48 PM • HP 15.6" Compaq... • Answered on Dec 23, 2013
Cannot read sd cards
CardS ? You mean several of them ? What is their capacity ? (the question behind is are you sure they are SD cards, and not SDHC Cards or SDXC Cards, some of them perhaps not supported by an aged card reader)
10/23/2013 11:13:36 AM • HP 15.6" Compaq... • Answered on Oct 23, 2013
Scanner won't work with compaq cq58
You orobably do not have the required drivers for the scanner. I suggest you to browse the manufacturer's website and download and install the latest updates from there. Also if they recommend any utitlity along with driver intall it and then try to scan the document. This will hopefully resolve the issue.
9/19/2013 1:36:45 PM • HP 15.6" Compaq... • Answered on Sep 19, 2013
How to replace an inverter for a hp compaq cq58
Remove the screen surround you will see it at the bottom of the screen
8/19/2013 10:33:11 PM • HP 15.6" Compaq... • Answered on Aug 19, 2013
I think I have a virus
I would download freeware MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In Safe Mode with Networking if necessary. In the install UNCHECK the Trial Pro Version, you want the freeware version, run a FULL scan, delete ALL results, reboot normally. I use AVAST FREE 8.0.1489: http://www.fixya.com/answer/answerpageslideview.aspx?ctg=8&thid=18108057 Haven had a Virus in years. Give it a try, it's always rated high in Anti Virus and it's free! First, of course, you have to remove McAfee with the McAfee removal Tool found on the McAfee website.
5/27/2013 1:47:59 AM • HP 15.6" Compaq... • Answered on May 27, 2013
What now
From the boot manager screen you have to go Change defaults or choose other options. Then select Choose other options.Then select TroubleshootThen select Advanced optionsThen select Startup SettingsThen click restart.This will restart your computer and will give you a list in which you will select from. It should be option 4
5/23/2013 10:43:44 PM • HP 15.6" Compaq... • Answered on May 23, 2013
Virus? Hard Drive Failure? Help Please!
This is because the Hard Disk Drive has failed and you need it replaced. If your warranty is still valid, take it back for repairs or buy another hard disk drive altogether.
5/20/2013 2:45:20 AM • HP 15.6" Compaq... • Answered on May 20, 2013
How do i turn webcam on in chatrooms
Look for setting in the "chatrooms" software you are using to setup the webcam, if the option is available. There are Many Chat sites.
3/28/2013 11:38:57 PM • HP 15.6" Compaq... • Answered on Mar 28, 2013
HP 15.6" Compaq Presario CQ58-A10NR Laptop PC with AMD E1-1200 Logo
Popular Tags
40 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
replace inverter hp compaq cq58
  • Computers & Internet
