20 Most Recent
B&K Reference 200.7 7-Channel Amplifier Questions & Answers
I need a volume control for a b&k avr305 can
Well you can load BFD filters. But before you inserted a BFD between your AVR and sub you simply set up the balance between all your speakers and sub with the AVR trim controls and AVR test tones. Then your master volume of the AVR was your main volume control.
The situation hasn't changed much after inserting a BFD, other than you should not disturb the setting you set on the AVR sub trim because you may cause clipping or low level inputs into the BFD. So, use the subwoofers own amplifier volume to balance levels rather than the AVR sub trim.
Thanks
9/5/2009 7:59:44 PM •
B&K Audio...
Answered
on Sep 05, 2009
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
