20 Most Recent Mountain Plumbing Mountain The "Little Gourmet" Heating Tank MT641 Questions & Answers
You need the push tool to release the internal spring.
Mountain... • Answered on Feb 02, 2015
Have you tried refilling your radiator looking for an air pocket?
Mountain... • Answered on Oct 26, 2013
if it is a ribbed fitting then yes
Mountain... • Answered on Feb 02, 2011
most of the units have a screen on the inlet that may be plugged
Mountain... • Answered on Dec 10, 2010
Same problem Leaking unit!... and also saw issues with the thin rubber hose.. other listed that their hose melts!!
Mountain... • Answered on Nov 23, 2010
You need a radiator bleed valve key. They are about the size of half a little finger with a 't' bar at one end and a small square socket at the other. made in brass or aluminum
Any DIY shop should have them
Mountain... • Answered on Jan 22, 2010
Not sure if you are In Uk but Danfoss manufacture these and are available fron The likes of B.S.S.
Mountain... • Answered on Jan 21, 2010
the temp is to high and it is just a neoprheme hose go to the hard ware store and purchast a new hose the samt size 3/8 re install it and trun the temp down on the unit, make sure the hose you get has at least 140 degree rating
Mountain... • Answered on Nov 30, 2009
No attack on this scale is heating element that dissolves when it is possible to disconnect apperaat water heating and draining than doing it in vinegar and let the heat once again connect and then empty and most calcium is removed from apperaat
Mountain... • Answered on Nov 08, 2009
It may be a push n lock. If you can send a pic of your phone vam, send one and we can see what's needed. [email protected]. If its a push n lock, While pushing on the line push in the smaller inner sleeve and pull on the line. Make sure there is not pressure in the line.
Mountain... • Answered on Sep 22, 2009
Mountain Plumbing Mountain The "Little Gourmet" Heating Tank MT641 Logo
25 questions posted
Top Mountain Plumbing Water Heaters Experts
Bill Boyd
Paul Carew
David Spradling
David Spradling
Are you a Mountain Plumbing Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Mountain Plumbing Water Heaters
Most Popular Question
leaking tank
  • Water Heaters
