20 Most Recent Star 301HLD Deep Fryer Questions & Answers
2answers
The unit is on but
Disconnect first the unit from power source, Locate the terminals of the hi limit and thermostat then remove either one of the wire connected to it. Using an ohm meter, check for the continuity across the terminals. If the hi limit has continuity across its terminals, it is good. Thermostat will have continuity across its terminals when set to a higher temperature, you will also hear a clicking sound when its mechanical contacts engage.
9/1/2011 11:02:23 AM • Star 301HLD Deep... • Answered on Sep 01, 2011
I have no cord is it a 220 or 120
Model 301hld ... this is a 208-240 VAC unit
Rated wattage
208V = 4130W
240V = 5500W
Nominal Amps
208V = 19.9A
240V = 22.9A
NEMA Plug = 6-30P
4/12/2011 5:49:25 PM • Star 301HLD Deep... • Answered on Apr 12, 2011
The item will turn on and begin to heat but it
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If this is electric then you have a burned out element...
if this is a gas unit,,,
Your problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
9/9/2010 12:51:01 PM • Star 301HLD Deep... • Answered on Sep 09, 2010
Star Mfg Popcorn machine 39R-A popcorn kettle will not heat. Blew a circuit while popping a batch of popcorn and now the kettle will not heat up.
First, check the circuit breaker to make sure it has not tripped. If it has, reset it and see if the kettle heats up. If it does not, then you may need to check the wiring to make sure it is connected properly. If the wiring is connected properly, then you may need to replace the heating element.
2/22/2023 10:27:13 PM • Star Kitchen... • Answered on Feb 22, 2023
Red star bread maker manual
I'm sorry, but I don't have access to specific manuals for individual bread makers. However, here are some general steps you can follow to find a manual for a Red Star bread maker:
  1. Visit the Red Star website: The Red Star website may have a library of manuals for its bread makers, including the one you have.
  2. Check the manufacturer's support page: Most manufacturers have a support page on their website where you can find user manuals, FAQs, and other resources.
  3. Search online: You can also try searching online for a digital copy of the manual. Websites like ManualsLib and ManualsOnline may have the manual you need.
  4. Contact the manufacturer: If you're unable to find the manual online, you can contact the manufacturer directly and request a copy. You may need to provide your bread maker's model number and other information.
I hope this helps you find the manual you need for your Red Star bread maker.
2/12/2023 10:26:54 AM • Star Kitchen... • Answered on Feb 12, 2023
I have a Star 49 popcorn machine, the kettle trips the breaker when attached, but if I detach it (no hinge connection, no metal to metal contact), it does not. Thoughts?
I would suspect that the heating element is shorted to ground, which machine provides.
6/26/2019 3:15:40 PM • Star Kitchen... • Answered on Jun 26, 2019
Red star bread machine manual
try website or manufacturer.
11/2/2017 7:32:07 PM • Star Kitchen... • Answered on Nov 02, 2017
Lights flickering
You could have a loose or a burned wire connection at the switches. If there is more than one thing not working correctly unplug the unit and check the black wire from the lead in cord. It goes to the switches and jumps from one switch to the next. That's where I would look first?
8/21/2016 7:39:57 AM • Star Kitchen... • Answered on Aug 21, 2016
What size is a 89d
THE 89D ISA 14 OZ KETTLE
7/3/2016 9:20:53 AM • Star Kitchen... • Answered on Jul 03, 2016
Star 301HLD Deep Fryer Logo
5 questions posted
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Star Kitchen Appliances - Others
Most Popular Question
unit but
  • Kitchen Appliances - Others
