20 Most Recent HiTi S420 Passport ID Photo Printer Questions & Answers
How can i reset hiti s420 printer
how to resat hiti s420 printer
8/21/2021 8:22:39 AM • HiTi S420... • Answered on Aug 21, 2021
2answers
Hi, I have a photo printer hiti S420 but always says image device error
pls change the board
10/6/2018 3:50:57 PM • HiTi S420... • Answered on Oct 06, 2018
When current gone out and come again printer
Check LE & Jam Sensor connection
6/24/2016 11:15:11 AM • HiTi S420... • Answered on Jun 24, 2016
USB NOT WORKING
change the board
6/14/2016 10:34:28 AM • HiTi S420... • Answered on Jun 14, 2016
0answers
0answers
USB NOT WORK
Be the first to answer 5/21/2015 11:02:12 AM • HiTi S420... • Posted on May 21, 2015Be the first to answer
Paper jam in Hiti P100s
pls the head of printer
9/16/2016 9:03:01 PM • HiTi Office... • Answered on Sep 16, 2016
How to find MAD on an fx-9750GII calculator
You can use the built-in MAD function on the calculator by following these steps:
  1. Press the "STAT" key and then select "5:Distribution". Choose "1:Statistical Calculations" and then "4:Other".
  2. Select "4:MAD" and then enter your data set.
  3. Press "EXE" to calculate the MAD.
3/20/2023 11:00:11 PM • Office Equipment... • Answered 15 hours ago
My Sinotech projector red light stays on, but doesn't want to switch on, not with remote nor the Power button on projector.
This is a South African brand. We are in North America. Contact their Support department direct. Check the bulb for continuity first. https://www.sinotec.co.za/contact/ ..
3/20/2023 4:08:19 PM • Office Equipment... • Answered 22 hours ago
Caster holder broken and won't auto-stop after shred
I see you posted two questions on the same issue, and the other one was disjointed with no indication what the caster wheels were on. Check the switch, they normally have On, Off and Auto. Remove the head and clean all paper debris from underneath. You have a small piece of paper over the sensor and it is sensing that there is still paper for be shredded. Some have a small lever and if so, yours is stuck. Spray with WD40, and all the blades as well. https://www.google.com/search?q=Ativa+MDM+8000 The caster wheels could all be removed and have it sitting on its base. The wheels are for use if you keep it in an office cupboard. You just replace the whole caster wheel or the whole set for $14.. https://www.google.com/search?q=Caster+wheel ..
3/19/2023 3:59:16 PM • Office Equipment... • Answered Yesterday
2answers
Milnor commercial washer??
Yes, Milnor is a commercial washer manufacturer. They offer a range of equipment, including industrial and commercial washers. Their products are used in a variety of laundry applications and are designed to provide maximum efficiency, reliability, and performance.
3/18/2023 8:08:46 PM • Office Equipment... • Answered 2 days ago
2answers
Milnor commercial washer model # 30022T5X
The Milnor 30022T5X0 is a commercial washer that features a high-speed extraction system, low water usage, and a convenient front-load design. It offers a capacity of up to 25 pounds and can handle a variety of fabrics, including towels, sheets, and uniforms. The 30022T5X0 also features an energy-efficient design and an adjustable water temperature for better cleaning results.
3/18/2023 8:08:11 PM • Office Equipment... • Answered 2 days ago
Have a Staples Model SPL-727MM paper shreader that
I am sure you have already solved it or moved on but johnd393's comment at https://www.fixya.com/support/t1766897-disassemble_mailmate_spl_727mm helped me. To reach the screws in the tray drill 6 holes in the bottom plastic and use a really long screwdriver to access them. I used a 12 inch uxcell #1 Phillips screwdriver, which also worked on the 2 long screw holes hidden under the feet. You could probably get away with 10 inch or a #2 Phillips but with #2 screwdrivers check the width of the shaft first as the screw holes under the feet were too small for the #2 I originally bought.
3/18/2023 8:04:43 PM • Office Equipment... • Answered 2 days ago
I have a problem with Riso SF5030, it shows error code P98-1061/ T98-1061. What maybe the problem
Hi! Error codes P98-1061 and T98-1061 on the Riso SF5030 indicate an issue with the color drum's motor. This error code usually occurs when there is a problem with the motor or the wiring that connects the motor to the printer's control board. Here are some steps you can take to troubleshoot the issue:
  1. Turn off the printer and unplug it from the power source.
  2. Check the wiring connections between the motor and the control board. Make sure that they are secure and not damaged.
  3. Check the motor for any physical damage or signs of wear and tear.
  4. If you have a replacement motor, try replacing the faulty one and see if the error code persists.
  5. If the issue persists, you may need to contact a service technician to diagnose and repair the problem.
It's essential to note that opening up the printer's internal components can be dangerous, and you should only attempt these steps if you feel comfortable doing so. If you are unsure or uncomfortable, it's best to contact a qualified service technician for assistance. Regards
3/18/2023 6:51:14 AM • Office Equipment... • Answered 3 days ago
How to fix Riso cv 3230with error code p 01 -537
To fix the error code P 01 -537 on a Riso CV 3230, you will need to reset the machine. To reset the machine, press and hold the Stop/Reset button for at least five seconds. This will reset the machine and clear the error. If this does not work, then you may need to perform a deep reset of the machine. To perform a deep reset, unplug the machine from the power source and then plug it back in. Allow the machine to go through its startup sequence and then test the machine again.
3/17/2023 10:47:14 AM • Office Equipment... • Answered on Mar 17, 2023
How to clear error code 78?
Error code 78 is a common error code that can appear on a variety of devices, including computers, printers, and other electronic devices. The exact cause of this error code can vary depending on the device, but it usually indicates a problem with the device's hardware or software.
One of the first steps to clear error code 78 is to try restarting the device. This can often clear any temporary glitches or errors that may be causing the problem. If the error code persists after restarting the device, the next step is to check the device's manual or manufacturer's website for troubleshooting steps specific to that device.
If the device's manual or website does not provide any specific steps for clearing error code 78, the next step is to perform a general troubleshooting process. This may involve running a system scan for viruses or malware, checking for software updates or patches, or performing a hardware diagnostic test.
If these steps do not clear the error code, it may be necessary to contact the device's manufacturer or a professional technician for further assistance. In some cases, the device may need to be repaired or replaced to resolve the issue.
In summary, clearing error code 78 requires specific troubleshooting steps that may vary depending on the device. Restarting the device, checking the manual or manufacturer's website, performing general troubleshooting steps, and seeking professional assistance may all be necessary to resolve the issue.
3/16/2023 5:16:48 PM • Office Equipment... • Answered on Mar 16, 2023
Miroir M20 Micro LED Projector. Code for Miroir M20, it's not stolen and has no remote to it.
Question edited for clarity. Question moved from Television category. Did you find it in a Dumpster? You can't do anything without a remote and only the maker will tell you the code based on the serial number. https://www.google.com/search?q=miroir+m20 ..
3/15/2023 4:08:38 PM • Office Equipment... • Answered on Mar 15, 2023
Rexel LV250HS Laminator stopped heating up. Can it be repaired.
Question edited for a lot more clarity which a guess at the maker. Question moved from Microwave Oven. It depends. If it is just a broken wire or a faulty switch, probably yes and easily. If the heating element has failed, getting spare might be the hard part. Start with checking the easy stuff with a multimeter.
3/14/2023 10:49:22 PM • Office Equipment... • Answered on Mar 14, 2023
HiTi S420 Passport ID Photo Printer Logo
8 questions posted
Top HiTi Office Equipment & Supplies Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a HiTi Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • HiTi Office Equipment & Supplies
Most Popular Question
  • Office Equipment & Supplies
