20 Most Recent
HiTi P110S PocketStudio Photo Printer Starter Kit Questions & Answers
It turns on and 5 seconds later e4 code pops up
The "E4" error code on a T9200 Vision Fitness treadmill typically indicates a problem with the incline motor. This could be caused by a malfunctioning motor, a problem with the wiring or connections to the motor, or an issue with the incline sensor or control board.
Here are a few things you can try to troubleshoot the problem:
- Check the wiring and connections: Inspect the wiring and connections between the incline motor and the control board to make sure that they are securely connected and not damaged.
- Check the incline sensor: Make sure that the incline sensor is functioning properly and that it is not blocked or damaged.
- Check the control board: Make sure that the control board is functioning properly and that it is not damaged.
- Check the incline motor: Make sure that the incline motor is functioning properly and that it is not damaged.
It's important to follow the instructions carefully and if you have any doubts or difficulties, consult the treadmill's user manual or contact Vision Fitness customer service for assistance. It's also important to note that it is recommended to have a professional technician to perform this task as it may cause other issues if not done properly.
HOW CAN I GET MY CALCULATOR TO TURN ON?
Depends on what the MYSTERY calculator is!!
Some have a switch on them. Some start up when you press the Clear button or even expose the solar cell to light.
Google
make model manual
All questions need 'make model (what it is)', first three words.
I put ON,my copier,but,goes,ON,quickly
If your Minolta Di152 copier is turning on and off quickly, it could be caused by a few different issues. Some possible causes include:
- Overheating: If the copier is overheating, it may automatically turn off to prevent damage. Make sure that the copier is in a well-ventilated area and that there is nothing blocking the airflow.
- Power supply: The power supply could be faulty. Check the power source and ensure that it is providing the correct voltage.
- Fuser: The fuser unit could be malfunctioning. The fuser is responsible for heating and fusing the toner to the paper. If it is not working properly, the copier may turn off.
- Control board: The control board could be malfunctioning. This could be caused by a software or firmware issue.
It is recommended to check the copier's manual or consult with the manufacturer's technical support to troubleshoot the problem. They may provide more specific instructions for your specific model and can guide you through the process of finding and fixing the problem.
E studio283p can not print by lan and also usb connection
There are a few potential issues that could be causing your E studio283p printer to not print when connected via LAN or USB. Some possible causes include:
- The printer driver is not installed or is out of date. Make sure you have the latest driver for your printer installed on your computer.
- The printer is not properly configured on your network. Check the printer's IP address and ensure that it is correctly set up on your LAN.
- The USB cable is not properly connected. Ensure that the cable is securely connected to both the printer and your computer.
- The printer is not turned on or is not properly connected to power.
- There is an issue with the printer's firmware or hardware.
You may try to troubleshoot the problem by checking the printer's manual or consulting with the manufacturer's technical support.
Resetting default number of copies to 1
It sounds like you are trying to reset the default number of copies on a printer to 1, but someone previously set it to 26 and you are unable to change it back. Here are a few methods you can try to reset the default number of copies to 1:
- Check the printer settings: Look for a settings menu or control panel on the printer itself, or on your computer or mobile device if you are connected to the printer over a network. Look for options related to the number of copies, and try to change it to 1.
- Check the print driver settings: Look for the print driver settings on your computer or mobile device. The print driver is the software that communicates between your device and the printer. Look for options related to the number of copies, and try to change it to 1.
- Check the print queue: Look for the print queue on your computer or mobile device. The print queue shows all the documents that are waiting to be printed. Look for options related to the number of copies, and try to change it to 1.
If none of these methods work, it may be necessary to contact the manufacturer of the printer for further assistance. It's also important to check if the default number of copies is set to 26 on the specific software you are using to print such as a certain program or website.
Good day i have a problem with my bizz hub c252 machine its showing a error code saying c-d231
The error code C-D231 on a Konica Minolta Bizhub C252 machine indicates a problem with the drum unit. The issue could be caused by a number of things such as a dirty drum unit, worn drum unit, or a problem with the drum unit's connection to the machine. It is recommended to try cleaning the drum unit first, and if the problem persists, to contact a technician for further assistance. It's possible that the drum unit need to be replaced.
Hope this solves your problem, have a nice day
