20 Most Recent
Hansgrohe Thermo II Rough-In Valve Chrome 06623000 Questions & Answers
Adjusting water temp
Behind the handle there is usually a scald gaurd on the newer faucets. You can adjust it from there. If your not sure, follow this link and download the installation instructions to your faucet. There you will find how to adjust it step by step.
http://www.hansgrohe-usa.com/us_en
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock.
Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
