20 Most Recent Kodak Esp 1.2 All-In-One Printer Questions & Answers
To help you troubleshoot the issue, please follow the steps as given below:
- Make sure printer power connections are firmly connected to both end of power connector.
- Make sure power switch is turned on.
- Please try swapping the power point that is working properly.
- Please change the power cord to see if that is the issue.
- If issue persists, it is recommended to contact 'Kodak Support Center' from the link given below for further troubleshooting as it might be internal hardware issue:
http://support.en.kodak.com/app/contact/selected/true
GuruAid.com
Kodak Esp 1.2... | Answered on Jul 04, 2016
clean rollers or order new ones for 50 cents, just google search for the rollers, also check to see what weight paper you are using, it may work with other or check paper size setting in printer setup. photo paper can be a problem re pick up with some printers
Kodak Esp 1.2... | Answered on Feb 08, 2016
I'd uninstall the printer. Unplug the USB cable to the printer and power down the printer. Reconnect the cable, power up the printer and in control panel/printers "add printer" it should find the printer and install the latest driver.
Kodak Esp 1.2... | Answered on Sep 15, 2015
On Printer Driver there is maintenance setting where you can perform head cleaning. just follow the instructions to do so..
Kodak Esp 1.2... | Answered on May 09, 2015
bad power supply, chyeck it with a ohm meter if you can, Matt
Kodak Esp 1.2... | Answered on Jan 28, 2015
check your print head it is stopeed up, remove it and clean with water just the jets, or use qtips, plain water no chemicals, Matt
be sure that the power supply is receiving the voltage
Kodak Esp 1.2... | Answered on Dec 05, 2014
It could be a number of reasons:
1. a simple solution is to initiate what is called, 'power recycling' (although this is assuming that the printer did already work at some prior point); this is where you turn off the printer for about 5 minutes, then turn on, which usually allows the system to reengage itself.
2. did you install the software for the printer? If you did not then your PC might not know the printer is attached. Is the software installed properly?; meaning you must unplug the printer from the PC, then install the software, then connect the printer to the PC after the software is completely installed. If you did it in reverse, then you need to uninstall the software, then start over by doing what I just mentioned.
3. the USB port you have the printer cord inserted into could be bad on your PC.
4. the printer itself has an internal problem and needs to be repaired, or if the warranty is still in place, have it replaced with another new unit.
Kodak Esp 1.2... | Answered on Jul 27, 2014
As soon as the alignment sensor does not work correct, or does get information it does not expect you get an error.
The band whit the very small lines on it, should be clean and in one piece. It is connected to the print head and registers the slightest movement of the head. Check if the band is there and if it looks "new"
Kodak Esp 1.2... | Answered on Jul 23, 2014
Kodak Esp 1.2 All-In-One Printer Logo
76 questions posted
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
ESP Kodak
  • ESP Kodak
Most Popular Question
kodak esp 1 2 wont turn
  • Office Equipment & Supplies
