20 Most Recent Sunbeam 701 Humidifier Questions & Answers
2answers
Humidifier runs but no cool mist comes out.
1 amp fuse on circuit board blown... replace
2/18/2017 1:52:44 AM • Sunbeam 701... • Answered on Feb 18, 2017
2answers
Working, but not blowing mist.
I think I found the problem.
unplug humidifer, remove top tank, empty all water out of base. dry off.
turn unit upside down.
unscrew five visible screws.
use a screw driver to pull off the black foam foot pads. you will find more screws there.
pull off the base.
look next to the fan, you will see a metal "tower" going up into the reservoir. Is it dirty such as white chalky substance on it? Clean it with cotton swabs. Clean the fan while your at it if needed.
You will see a small gray box with two metal tabs twisted. Untwist them and pull off the top.
On that metal "tower" you will see a small black chip connected to the circuit board where you just removed the metal top. Does black chip have black marks on the circuit board? Mine does. I suspect the "tower" which draws heat from this black chip was no longer able to cool because of the white chalk buildup on the tower, furthermore, the chip became too hot and caused the black chip to overheat (again black marks on the circuit board).
The chip has on it "FTR 02N" and a "54F" at the bottom. I tried doing some basic searching on internet to see if it could be replaced, but didn't find anything.
For those who don't have this problem yet, just keep that metal cooling tower clean.
12/18/2012 5:54:38 PM • Sunbeam 701... • Answered on Dec 18, 2012
2answers
We have a Sunbeam Cool Mist Ultrasonic Humidifier
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
1/26/2012 3:58:00 PM • Sunbeam 701... • Answered on Jan 26, 2012
I purchased a used Sunbeam Humidifier SWM5602 and
Lana, apparently that Model Number may have been discontinued. However, your Owners Manual may be available by calling Sunbeam Appliance @ 888 -264-9669.
Hope this helps you get the manual.
Rich
3/29/2011 7:58:52 PM • Sunbeam 701... • Answered on Mar 29, 2011
How do I clean & sanitize humidifer
Use vinegar!
12/2/2010 4:01:43 PM • Sunbeam 701... • Answered on Dec 02, 2010
How do I clean/sanitize my humidifier?
A solution of water and white vinegar will remove the mineral deposits built up from the water. Rinse "very" good, then wash out with a solution of 1 part bleach and 3 parts warm water.
3/31/2009 2:15:15 AM • Sunbeam 701... • Answered on Mar 31, 2009
Humidifier not producing enough vapour
have you looked to getting a whole house humidifier. This elinates the need to constanly put water in a can. And they are relatively maintenance free.
2/9/2009 8:42:54 PM • Sunbeam 701... • Answered on Feb 09, 2009
I recently found a Sunbeam humidifier without a manual. 1. What filters go in it? 2. Do you have a manual? I think I'm missing a part to this humidifier. Thanks.
Yes Truly Blessed, we do have all the manuals if you can find the model number on the label. They are all listed here on our website.
Home Comfort ... - Sunbeam Canada Instruction Manuals
https://www.sunbeam.ca > home-comfort > humidifiers
Instruction Manuals for Home Comfort Products, Humidifiers. ... SUL1410-CN - Sunbeam® Ultrasonic Cool Mist Humidifier Instruction Manual EN-FR · 1361-705 ... You can get filters from us
Humidifier Filters & Accessories: Find your filter ... - Sunbeam
https://www.sunbeam.ca > en_CA > home-comfort > hu...
Find your filter for your Sunbeam® humidifier to keep the air in your house comfortable, water treatment tablets offer a light scent to the mist from your humidifier. and also from our Amazon resellers
Sunbeam Humidifier Filter - Amazon.ca
https://www.amazon.ca > Sunbeam-Humidifier-Filter
Results 1 - 48 of 849 - IOppWin 6 Pack Humidifier Filters Replacement for''A'' Holmes Filters, Compare to Part # HWF62, HWF62D,Compatible with Sunbeam Cool ...
4/16/2021 4:51:24 PM • Sunbeam... • Answered on Apr 16, 2021
My Cool mist Sunbeam humidifier needs tablets that do not exist. What is next?
I checked wal-mart near me and they have them. If you have a wal-mart near you call them to see if they have them also
11/16/2018 5:20:22 PM • Sunbeam... • Answered on Nov 16, 2018
I need a sunbeam owners manual for humidifier SUL2512
It is not listed in the Sunbeam web site at http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/humidifiers-and-heaters/humidifiers/humidifiers-and-heaters-humidifiers-manual.htmlHowever a chat with the agent was helpful and they emailed me a copy without fuss.
5/2/2018 9:58:25 PM • Sunbeam... • Answered on May 02, 2018
Sunbeam sul2512 humidifier leaking.
The Sunbeam SUL2512 Humidifier has three parts. From the top down: Water tank mist collar Base unit If the cap of the water tank (which contains a float valve) does not seal you may get excessive flow into the base unit which provides a working reservoir. The base unit contains all the electronics including the cool mist transducer. This is a silver disk with a black silicone seal surrounding it. This is the only other place a leak can develop.
5/2/2018 9:35:34 PM • Sunbeam... • Answered on May 02, 2018
How to clean the fan in sunbeam humidifier
Go to Walmart and get Canned Air used to blow out debris from keyboards etc. Place the air tube near the fan vents and blow out debris. Keep the can up-right. Should you turn it upside-down, you will FREEZE everything, so do it correctly.
2/7/2018 9:03:52 PM • Sunbeam... • Answered on Feb 07, 2018
Why does my Sunbeam humidifier turn on but not work?
If the water valve from the water container to the misting head is defective, contains particles, or fails to open; then no activity will occur. Clean the system with Vinegar solution and be certain to use distilled or filtered water in the future.
2/7/2018 8:41:15 PM • Sunbeam... • Answered on Feb 07, 2018
Sunbeam 701 Humidifier Logo
19 questions posted
Top Sunbeam Humidifiers Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
View Most Popular
Sunbeam Humidifiers
  • Sunbeam Humidifiers
Most Popular Question
sunbeam cool mist ultrasonic humidifier
  • Humidifiers
