20 Most Recent Krups Ea9000 Barista Espresso Machine Questions & Answers
Plug it in, turn it on and then within 3 seconds touch each of the 4 corners on the touch screen in this order Top left, Bottom right, Bottom left, Top right that should open up the settings options for you, follow your nose after that.
Krups Ea9000... | Answered on Apr 17, 2020
Check the float in the tank, if it is not floating up from the bottom then jam something plastic underneath it to activate the water level sensor. You can either continue to use it like that ans check water level before you brew or buy a new tank, there is no repair for a float.
Krups Ea9000... | Answered on Jan 24, 2016
Defective electronic components.
Krups Ea9000... | Answered on Nov 30, 2015
I have done XP9000, this may be similar. Remove side cover, operate lever on side of exposed brew unit and pull brew unit out with the handle. You can only do this when machine is in normal 'at rest' position. Unit will not come out in any other position.
Krups Ea9000... | Answered on May 07, 2015
Could it be that the machine needs a cleaning cycle to be run or a descale done. If neither of the above it will mean the machine has detected something about the process is outside normal parameters and should be looked at.
It can cause problems if it doesn't work correctly. To test the thermostat in a drip coffee maker: Step 1: Unplug the unit, empty excess water from the reservoir, turn the unit over, and remove the base. ... Step 3: If defective, remove and replace the thermostat with one of the same rating.
https://home.howstuffworks.com/how-to-repair-small-appliances3.htm
Krups Coffee... | Answered on Apr 01, 2020
Error code 5 is a result of one of the following:
Blocked water circuit (water meter, pump, distributor, distributor motor, microswitch)
Krups Coffee... | Answered on Mar 10, 2020
Hi! Did You fixed the problem? I got same error and have no idea whats the point :(
Krups Coffee... | Answered on Feb 17, 2020
Krups Ea9000 Barista Espresso Machine Logo
14 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
krups ea9000 dosing beans
  • Coffee Makers & Espresso Machines
