20 Most Recent Bialetti Easy Cafe Espresso Maker Questions & Answers
0answers
2answers
Hi, I bought a Bialetti mini express maker in Italy, but it does not seem to be working. The lights are on and the water pump makes a loud noise, but no water comes out. Can you please help? Thanks!
Did you two buy the machine in europe and travelled back to the USA? If so, the machine can't be used there. You will need a 230V power plug in the house before it can do anything. Otherwise you have to buy a power converter from 115 to 230 V. Hope this helps
2/23/2019 9:42:35 AM • Bialetti Coffee... • Answered on Feb 23, 2019
Dark grey stains (that appear un-removable) on the inside surface of coffee container
Try wiping the inside with damened paper towel and baking soda paste. Check towel to see if any removed. Rinse out with water. If it works, repeat if desired.
2/6/2018 6:58:23 PM • Bialetti Coffee... • Answered on Feb 06, 2018
The little side on/ off push button is broken on my red bialetti mokissima trio Can this part be replaced?
Acording with bialetti.com that part is not avaliable for replacement, someone who's familiar fixing electrodomestic stuff might give you a better opinion, if can make the trick for you for a few bucks or you can check if is just spring missing, if anything looks right, it could be a fuse inside but you have to open it to check, if you never fix nothing electric before, get some of your friends can check it for you on your presence, never ever leave your machine with no body, you can see it for the las time if you leave it with some one you dont know very well, like your husband or son.
10/25/2016 11:46:11 PM • Bialetti Coffee... • Answered on Oct 25, 2016
Steam relief valve releasing pressure before and
make sure your water level is not too high. needs to be just under release valve inside
9/19/2016 8:54:24 PM • Bialetti Coffee... • Answered on Sep 19, 2016
Bialetti mini espresso coming out very slowly
Hi there... have had this problem. sounds like you have minerals deposit problem. Put vinegar in water tank, then start machine to let all vinegar come out , it should clean it well. then do over again with water so next coffee doesn't taste like vinegar .If by the time the vinegar pasted through and water doesn't come out faster , it must be another problem. Hope this helps.
3/22/2015 2:19:21 PM • Bialetti Coffee... • Answered on Mar 22, 2015
Why coffee will not come out
Firstly check for clogged holes from where the water comes out. Clean out with big pin or the end of a paper clip. Second, check if mineral deposits have clogged the uptake of the water. Boil a round with diluted vinegar and rinse with several other rounds. Thirdly, make sure you have inserted the coffee holder component correctly i.e. snugly where it fits.
8/14/2014 11:12:20 AM • Bialetti Coffee... • Answered on Aug 14, 2014
Bialetti parts in Calgary
Lina's Market on Center St N
4/10/2014 7:10:50 PM • Bialetti Coffee... • Answered on Apr 10, 2014
Bialetti Easy Cafe Espresso Maker Logo
3 questions posted
Top Bialetti Coffee Makers & Espresso Machines Experts
Pierre Laplante
Kolbrun...
Ross Keen
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Bialetti Coffee Makers & Espresso...
  • Bialetti Coffee Makers & Espresso...
Most Popular Question
little side off push button broken red
  • Coffee Makers & Espresso Machines
