20 Most Recent Sunbeam 200 Watts 2484 Hand Mixer Questions & Answers
www.fixya.com/...sunbeam_200_watts_2484_hand_mixer/manual-5002
Sunbeam 200... | Answered on Jul 03, 2009
In taking apart my same beater, I'm trying to figure out the alignment of the spring which provides the tension so that the beaters won't fall out. I'd assume that your spring has mis-aligned. You need to take it apart (3 Philips screws), and carefully pull the assembly apart. I'll bet your spring falls out like mine did. I'm trying to find a schematic from Sunbeam to see how the spring should align.
Sunbeam 200... | Answered on Nov 01, 2008
Model number?
How to Obtain Warranty Service
In the U.S.A.
If you have any question regarding this warranty or would like to obtain warranty service, please call
1-800-458-8407 and a convenient service center address will be provided to you.
In Canada
1-800-667-8623 and a convenient service center address will be provided to you.
Sunbeam Food... | Answered on Jan 21, 2020
Request an assembly diagram from Sunbeam, then follow it in reverse.
Sunbeam Food... | Answered on Aug 20, 2019
It's from the early 70's and willbe grouped with the MM model of mixers. Here is a manual from the next model after your's;
http://www.davesrepair.com/manuals/MM2356ownman.pdf
Sunbeam Food... | Answered on Jun 12, 2019
you may need a diagram for this. There may be a diode in line with current. If so, it functions as a circuit breaker to keep from damaging the motor. If no current goes thru diode but is at the "front", then replace diode. Also something made the diode malfunction, so you need to investigate. My money is on the motor. It is probably starting to ground out.
Sunbeam Food... | Answered on Jan 25, 2019
Check the power wire that plugs into the power supply for anything that doesn't look right. Something could be loose inside also but don't attempt to dissemble it and fix it unless you're confident in your skills, otherwise any electronics shop could diagnose and likely fix it for a small fee.
Please click "Helpful" if you found gbis helpful at all. Have A Great Day!
Sunbeam Food... | Answered on Jan 16, 2019
You can probably get them from here, but you have to order their minimum quantity -
https://www.bumperspecialties.com
They have self adhesive pads that you can replace the old feet with, and you will have a couple hundred left over for about 20 bucks.
Sunbeam Food... | Answered on Jan 05, 2019
Sunbeam 200 Watts 2484 Hand Mixer Logo
4 questions posted
Top Sunbeam Food Mixers Experts
Vincent G
Vincent G
Bruce Showalter
efs_perpends
efs_perpends
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Sunbeam Food Mixers
  • Sunbeam Food Mixers
Most Popular Question
sunbeam 2484 beaters stay engaged
  • Food Mixers
