20 Most Recent Sunbeam 275 Watts 2369 MixMaster Series Hand/Stand Mixer Questions & Answers
You will need to search for a repair shop. There are replaceable parts in the speed control assembly that will cause your symptoms when they fail. The question is - can those replaceable parts still be obtained after 25+ years?
Sunbeam 275... | Answered on Jan 06, 2018
Retrevo has link to the Instruction manual for the MixMaster 2369 here: http://www.retrevo.com/support/Sunbeam-2369-manual/id/952ci068/t/2/ . You will need to enter a code to download the file. You will also need Adobe Reader or a similar program to read the file.
I hope this helps.
Sunbeam 275... | Answered on Nov 30, 2012
Zaczac,
There are two probable causes for this. One is that the insulation in the motor has broken down. This is definitely an unsafe condition, and unless you are a motor repair specialist there is nothing you can do.
The other cause is an accumulation of graphite around the brush holders. Fixing this would require pulling down the motor and cleaning the graphite away. This usually happens with motors that have done a lot of work.
It is normal that by the time the brushes have worn so much that the dust causes shorting the motor needs to be serviced.
Read this to understand what is required to pull the motor down and to reset the speed control:
http://www.fixya.com/support/t2208012-sunbeam_mixmaster_12_speed_may_need
Just cleaning the motor housing out thoroughly may get the machine running. I make no guarantees though. If the motor insulation is failing the motor will remain unsafe.
Sunbeam 275... | Answered on Jul 18, 2009
Model number?
How to Obtain Warranty Service
In the U.S.A.
If you have any question regarding this warranty or would like to obtain warranty service, please call
1-800-458-8407 and a convenient service center address will be provided to you.
In Canada
1-800-667-8623 and a convenient service center address will be provided to you.
Sunbeam Food... | Answered on Jan 21, 2020
Request an assembly diagram from Sunbeam, then follow it in reverse.
Sunbeam Food... | Answered on Aug 20, 2019
Sunbeam 275 Watts 2369 MixMaster Series Hand/Stand Mixer Logo
Popular Tags
15 questions posted
Top Sunbeam Food Mixers Experts
Vincent G
Vincent G
Bruce Showalter
efs_perpends
efs_perpends
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Sunbeam Food Mixers
  • Sunbeam Food Mixers
Most Popular Question
our sunbeam mixer stand variety
  • Food Mixers
