20 Most Recent Sunbeam 2346 Heritage MixMaster Series Stand Mixer Questions & Answers
You can try contacting your chamber of commerce for a reputable dealer or repair station. Or try https://www.ereplacementparts.com/
Sunbeam 2346... | Answered on Jan 06, 2018
contact sunbeam direct or on line and make enquiries
if it is more that 5 years old I don't fancy your chanches
Sunbeam 2346... | Answered on Jul 16, 2017
The mixer is not designed to be disassembled or serviced. When it breaks (and it will) Sunbeam will replace it under warranty if you are lucky or you toss it in the trash.
That said, start by prying out the beater release button. There are two small screws under it and one between the beater inserts to remove the chrome front cover. The large black dial at the rear can be pulled straight off, revealing more screws. The motor and drive assembly in the top cannot be removed without disconnecting wiring from the circuit board in the base.
Sunbeam 2346... | Answered on Dec 11, 2016
I hope this helps. I found on mine that the rear screw on the "neck" had become slighty loosecousing the release to not fully disingage. I had to remove the dome shaped cap in the middle of the speed control knob, pops off fairly easy, to gain access to the nut to tighten it. Hard part was trying to hold the screw head still while I used a small screw driver and small hammer to tap the nut tight, very limited space between the "neck" and motor body.
btsctn
Sunbeam 2346... | Answered on Feb 22, 2015
I'm in the middle of a bake sale. Not a good time to send back. Also, I think you meant a free Upgrade at no additional cost...
Sunbeam 2346... | Answered on Feb 08, 2015
Gently try to wiggle it out whilst pressing the button.
Sunbeam 2346... | Answered on Dec 09, 2014
the smell will be burning insulation on the windings of the motor probably from the brushes being too short and arcing on the armature thereby overheating the motor. suggest you take it to an appliance repair shop for quote on repairs.
Sunbeam 2346... | Answered on Jul 02, 2014
many of the beaters are available online. There are replacements available for the mixmasters.
Check for your specific model HERE...
Merry Christmas to you..
Sunbeam 2346... | Answered on May 11, 2014
Hi
Most of them have a button to push that releases the mixer head to tip back. Sometimes the buttons stick and will not release. That picture looks like you are using the Heritage model.
You have to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; tighten it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer you may also notice that the tilt release had become easier to use -- previously you may have found that you have to press the tilt release button very hard to get the tilt to unlock.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Sunbeam 2346... | Answered on May 08, 2014
This will definitely be a problem with the actual beater gearbox unit inside the front and under the top handle of the machine.
I've had my wifes one apart and it was difficult at best to even do that, so my recommendation is to take it back to the shop if it is still in the warranty period.
If not, take it to a small machine mechanic and get a Quote for repair before anything is done as it's quite likely that the repair will cost as much as a new mixer.
Sunbeam 2346... | Answered on Mar 20, 2014
Sunbeam 2346 Heritage MixMaster Series Stand Mixer Logo
85 questions posted
Top Sunbeam Food Mixers Experts
Vincent G
Vincent G
Bruce Showalter
efs_perpends
efs_perpends
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Sunbeam Food Mixers
  • Sunbeam Food Mixers
Most Popular Question
sunbeam stand mixer won 39 t tilt back
  • Food Mixers
