20 Most Recent Sunbeam SBM7500W Microwave Oven Questions & Answers
Timer knob stuck
needs cleaning
4/4/2013 12:38:32 AM • Sunbeam SBM7500W... • Answered on Apr 04, 2013
Wont get hot
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
5/5/2011 10:12:38 PM • Sunbeam SBM7500W... • Answered on May 05, 2011
My model# sbm7500w sunbeam microwave
heatman101
5/5/2011 10:09:46 PM • Sunbeam SBM7500W... • Answered on May 05, 2011
There is little or no heating effect from the microwave
In all likelihood the mangnetron has failed, or perhaps even the Power Supply.
2/17/2010 1:04:37 AM • Sunbeam SBM7500W... • Answered on Feb 17, 2010
Will my microwave work with no light on is it
If it is the inside light that is out it will not be a problem
10/18/2009 1:06:27 PM • Sunbeam SBM7500W... • Answered on Oct 18, 2009
Need instruction book
For assistance with your Sunbeam® Microwave, please call 1-866-257-3336.
1/9/2009 10:20:22 AM • Sunbeam SBM7500W... • Answered on Jan 09, 2009
2answers
My Sunbeam microwave stopped work 1 min into cooking something?
There could be a problem with your microwaves switchboard.Or the wiring connection is not good and causes it to heat up and causes the fuse to trip and then has the power shut off for your microwave.
7/3/2022 5:50:13 PM • Sunbeam... • Answered on Jul 03, 2022
Beeping on Sunbeam SGB8901 Microwave
Unplug microwave, open top, "several screws" look to where the keypad is, behind that you should see the control board, mounted you should see a round black device may be a speaker or pizza buzzer, verify that is sound.
6/15/2021 4:35:36 AM • Sunbeam... • Answered on Jun 15, 2021
My sunbeam sbg8901 does not respond to the start key after having accepted the amount of minutes
The start key could be defective.
3/13/2021 5:49:35 PM • Sunbeam... • Answered on Mar 13, 2021
4answers
I Bought an old Sunbeam
Hi
You can download the manuald from these links---
Sunbeam Steamer Manual Link 1
Sunbeam Steamer Manual Link 2
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
2/11/2021 4:45:25 PM • Sunbeam... • Answered on Feb 11, 2021
Hey. Am in Cameroon my sunbeam microwave am pressing figures and it doesn't appear on the board and for that reason it doesn't work. Thank you for the respond in advance
this fault is due to defective key membrane ,check by cleaning PCB assembly if same problem then replace the key pad assembly.
3/4/2019 9:36:20 AM • Sunbeam... • Answered on Mar 04, 2019
Sunbeam microwave display light not on. Inside lamp on and turntable spending slow when plugged in. Nothing working properly on display screen; no buttons, no on light.
you will have to decide if is cheaper to fix or replace. Microwaves are inexpensive. find parts and someone to fix it mat be difficult. I would reple it and move on. You can chose from several makers. prices start at $39.00 up to $150.00. look at Walmart, home depot
11/12/2018 2:09:32 AM • Sunbeam... • Answered on Nov 12, 2018
My Sunbeam convection oven's bowl cracked and need to find a replacement in Cape Town. I am in Brackenfell .Any surrounding areas in Cape Town where I could purchase one?
Hello, Alletta -I have not found any South African source for a replacement glass bowl for a Sunbeam convection oven.If you have not yet contacted Lategan & Van Biljoens in Pretoria and asked if they can locate and supply you with one, this is the Contact Us link for the business:https://www.appliancespares.co.za/contact%20us.aspxI did find a business in New Zealand which seems to sell the replacement bowls:https://www.needapart.co.nz/buy-online/sunbeam-convection-oven-bowl-co3000-10120169The part number for the bowl is: CO3000101One option you may wish to consider is to look for and purchase a used Sunbeam convection oven (same model number as yours), which has an intact glass bowl. Then, keep and use the convection oven which is in the best condition (yours or the used one you purchased). Hold onto the other convection oven (without the bowl) in case you need it to cannibalize parts to repair the unit you are using or in case you need to switch out the units if the one you are using stops working.Best wishes.
10/28/2018 5:57:58 PM • Sunbeam... • Answered on Oct 28, 2018
I have a brand new Sunbeam 0.9 Cu. Ft. Microwave Model SGB8901 that runs but I want to silence all button sounds including finish alert
Open the case and cut or disconnect the wire to the device that emits the sound. Likely it is not a speaker but a pizzo electric device. The manufacturer's do not usually include any way to turn this function off. You have to do it by brute force.
10/2/2018 6:23:57 PM • Sunbeam... • Answered on Oct 02, 2018
? Can I get a manual mailed to me for a sunbeam microwave Model. SgDJ701
not by fixya can try manufacturer for one
9/21/2018 7:27:45 PM • Sunbeam... • Answered on Sep 21, 2018
Sunbeam microwave Sgg5701 will not turn off,had to unplug from wall.
As a fire hazard, either get professional repair or discard it - marking it if so, to indicate fire problem if someone salvages it from the trash.
4/24/2018 11:49:12 PM • Sunbeam... • Answered on Apr 24, 2018
Sunbeam SBM7500W Microwave Oven Logo
18 questions posted
Top Sunbeam Microwave Ovens Experts
Paul Bade
Marvin
Marvin
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sunbeam Microwave Ovens
Most Popular Question
need instruction book
  • Microwave Ovens
