20 Most Recent
Kohler CLEARFLO BATH DRAIN K-7160-TF-BV Questions & Answers
Stem broke
Below is a link to the care guide with service parts for your model of drain. If you scroll to page number 20 it shows an exploded parts diagram, figure out what piece you need and call a local plumbing supply store with the part number, they can get you the part within a few days for most likely alot cheaper than it would be to replace the entire drain.
http://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1101880_2.pdf
Tub drain would not work
kohler hooks on to kinda of a coiled spring that you just unscrew,after you take the two screws out of the trip lever keep turning it to the left until it pulls right out.the stopper for the water slides into that spring at the height to make it go up and down with the trip lever,Ive done lots of them but its hard to explain. if not can you get at it in the basement?
Water entering twist mechanism which closes K-7160...
If the water is entering through the overflow on the twist mech. then the gasket should be tightened and or adjusted. If possible feel around on the top of that fitting from the back side to rule out water leaking from other source, such as backsplash or faucet from escutcheons. It sounds like you have a pretty good idea of how to fix it. I hope this helps.
How do I remove the plastic insert to access the cartridge on a Kohler K-171 kitchen faucet?
To remove the plastic insert on your Kohler K-171 kitchen faucet, you can follow these steps:
First, turn off the water supply to the faucet.
Next, remove the handle of the faucet by unscrewing the set screw on the underside of the handle using a hex wrench or an Allen key.
Once the handle is removed, you should see a plastic insert that covers the cartridge. To remove this insert, use a flathead screwdriver to gently pry it off.
Once the plastic insert is removed, you should be able to access the cartridge.
If you need more detailed instructions, you can refer to the installation manual for your Kohler K-171 kitchen faucet .
Valve is set to far into the wall...
First, your not going to like the solution. There really is no way to solve this on kohler faucets. Some companies make adapters but as far as I know kohler isn't one of them. Hopefully you can cut a hole in the drywall behind and put it where it should be, if not the marble comes back off.
