20 Most Recent
Sunbeam 4039 Iron Questions & Answers
HI, I DONT KNOW HOW TO OPEN MY SHARK RETRACTOR
Right below the button that you press to select fabric is that black rubbery piece. Use a screw driver to pry it up and then remove the three screews holding down the rest of the retracter. Mine was getting power to the circuits so I trashed it. I won't ever buy this brand iron again has it did not last very long.
good luck
Sunbeam steam valet instructions
How to fill your Sunbeam Steam Valet
Here is how you fill your Steam Valet. Press the small button on the back of the handle and pull bottom of handle apart from the top half of steam valet. Then take off the white cap on the inside of the handle and fill with water to top. Place cap back onto the opening and slide handle back and click in place. Plug in and you're ready to steam within a few minutes. If it spits out water let heat up a little longer if that doesn't stop it then tie a thin cloth over the top part where steam comes out to keep the water from spitting out onto your fabric. Hope these instructions are clear enough. More questions about this iron go to www.manualslib.com.
Find water demineraliser for use in a steam iron
Any undersink reverse osmosis system will give you the low tds high quality water needed for the steamer. Make sure the ro system does not have a mineral cartridge to add back calcium that it removes from water.
