20 Most Recent Amana VTH12 12,000 BTU Vertical Terminal Air Conditioner System VTAC with Heat Pump and Choice of Back-up Electric Heater Size Questions & Answers
if voltage to heater element bad element if no voltage bad control board
Amana Heating &... | Answered on Apr 01, 2020
check manufacurer tech support for info
Goodman Industries has purchased Amana. So go to Goodman website for info. Without model number I cannot look up error code
Amana Heating &... | Answered on Feb 19, 2020
You need to reinstall the software http://rollingskygame.com/run-3
Amana Heating &... | Answered on Dec 02, 2019
What is -the outside?
Heat pump, gas, electric heat combination?
You may need to back track, double check the Honeywell configuration jumper or software settings for your type of heating used.
Amana Heating &... | Answered on Nov 09, 2019
check for flame below flame sensor possible blockage of tube
Amana Heating &... | Answered on Oct 19, 2019
There should be a fan symbol on your remote control. In the "mode" control, there should be the following options.. Heat, cool, Auto and fan. If you select fan, only the fan will run. No heating or cooling.
Amana Heating &... | Answered on Jun 10, 2019
Check voltage in , there could be one side of breaker burned causing only one side to come through. This happens on older main breakers frequently which messes up whole house.
How are you determining that one section.is cold and one warm? If this is in fact the case you have a blockage in the coil or a compressor that is down provided this is a multi compressor unit.
Amana Heating &... | Answered on Feb 06, 2019
I'm leaning 2 directions, one is that your tstat is sensing your heatpump can not keep up with the load. Therefore bringing on heat strips or two, you have a cycles per hour limit set for compressor heating and your machine is cycling too often.
Amana Heating &... | Answered on Jan 27, 2019
Amana VTH12 12,000 BTU Vertical Terminal Air Conditioner System VTAC with Heat Pump and Choice of Back-up Electric Heater Size Logo
0 questions posted
Top Amana Heating & Cooling Experts
Bill Long
WatsHVAC
Level 1 Expert
Brad Scarpetta
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
trying get amana ap125 work after
  • Heating & Cooling
